Reversed Polarity (1 Viewer)
AdgeRas
473
13
Bristol
:Eeek:
I was reading another post, and went to the Dave Newell web site. One of the items he has recently got is "Polarity changeover switch".
In the description:
Dave Newell - Motorhome, Habitation, Servicing, Cruise Control, Camos Domes, Satelite Tv, Reversing Cameras look under 'Bits & Bobs'
They suggest and I quote "Foreign campsites are notorious for having reversed polarity on their hookup points which is potentially very dangerous."
Is this true, A: Foriegn camp sites are notorious? and B: Is this a dangerous issue?
Any advice and help is much appreciated as we will be getting our first MH in the next few weeks and will be going to Europe a great deal.
Thanks.
Adge.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
the safest way is dont use foreign campsites .you never kmnow what sort of riff raff you will bump into. i,m sure one or two on here have experianced this problem before i,m sure someone will have the answer . sorry i dont use sites cheers alan.heee,heee
Heyupluv
3,862
1,593
France,
touring many years..42+
:Eeek:
In the description:
Thanks.
Adge.
Yes to the first........
and
Yes could be to the second question...
from Mel in France
twooks
148
we always seem to stay on sites with 2-pin connectors and reversed polarity.
Not sure about how dangerous it actually is - but not about to argue with Dave :RollEyes:
my knowledge of electricity starts and finishes with finding the on / off switch.
Reverse polarity is a hoary old subject which invariables brings excited and opposite arguments on just about every forum I've ever lurked on
we carry
2 pin adapter, blue 3-pin lead + reversed lead, covers most eventualities.
Some people claim never to have encountered it, or indeed sites requiring the 2 pin adapter,
all I can say is that we've actually found different polarities on the same electric bollard.
but whatever you do - Don't Panic, and don't forget your towel :winky:
get over that bit of water and Enjoy, it's great :thumb::thumb:
43,331
49,467
the europeans dont seem to care which way the sockets are connected as they use double pole switches/breakers......both live AND neutral are switched off.
we use single pole so only the live is switched off.
if the hookup is reversed you will be switching the neutral off, not the live wire.
the appliance is still off but if you touch a live wire it will bite you !
and the rcd protection in the van wont work so it wont trip but it will at the hookup pillar.
in everyday use this shouldnt be a problem but you may find SOME appliances wont work if they have reverse polarity protection built in. .
S
stagman
:Eeek:
If you have been given proffesional advice . Then for your own and others safety . Take it . Don't cost much , and enjoy your hols .:thumb:
cater_racer
46
Chester
Don't worry too much, many "Reverse Polarity" signals are caused by no direct connection between neutral and earth.
Most generators will give a false "Reverse Polarity" signal for this reason.
However nearly all modern devices are double insulated and many have only two pin connections in the first place.
We carry a change-over lead, but in reality rarely bother with it unless we are staying several nights.
twooks
148
I can understand AdgeRas' reluctance to take advice at face value, you only have to look at the hype about 'gassing' to see that there can be vested interests at work in some of the adverts around.
Dave Newell is known, trusted and contributes to the Motorhome community - we've never had call to buy from him, but his advice has always seemed sound and well rated.
as Pappajohn sez, it's a problem unique to brits because of the way we set up our systems, the rest of europe are ok
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Adge.
Very very much less dangerous then driving to the foreign site.
Question: How many people reported electrocuted in/near a MH ?
Question: How many people killed driving a MH.
God has to really need you if you are to die due to a revered power lead - it has to be a reversed power lead plus a serious electrical fault - that being the case go joyfully.
Parcverger
Funster - Campsite Owner
Aug 13, 2007
459
443
Parc Verger - Limousin
RV
8 years
We took it seriously, and would not allow our electrician off of the site until I had personally checked every socket to ensure that we have no reverse polarity! :thumb::thumb:
Bob
rogerangie
15
Remember, NO ONE is infalliable. Mr Newall included.
43,331
49,467
Bob
you're to be congratulated on that bob, but you are english and understand the reasons for doing it 'right' for the brits :thumb:
Heyupluv
3,862
1,593
France,
Pappa you are right they do not seem to worry which way the electric flows or what colour cable they use for live......it could be brown...it could be blue, it could be yellow or even green, as long as the bulb lights and the motor turns ?????, or as it was in this property even yellow and green was used for live ( the person who wired this property was a top a railway electrician and goes all over France giving electrical lectures)!!! and yes there are many reversed polarity in France and as that other person said in the thread on the same borne!!!???? it is just a fact of life over here .......................Mel in France
The Wallace
367
5
Never found a reversed one in France but then we use mainly municipal sites which certainly look better maintained than some of the others we gave the go by. We have given up testing in France and no longer bother to carry a changeover lead.
HOWEVER, a couple of weeks ago I tested the first Danish hook up we had and it was wired opposite to the Brit way! So I then tested every bollard within easy reach and they were all the same. We went on to another 5 sites and they all tested the same ie reversed according to the Brit convention.
I took good care not to open any appliances whilst on hook up but then I cant be bothered opening any these days at home and just send for repair or recycling.
So do the Danes who come over here castigate Britain for having a notorious, dangerous wiring??
AdgeRas
AdgeRas
473
13
Bristol
:roflmto:Hahaha, the Wallace, you have hit the mark so wondefully. Ras is from Denmark, and is always banging on about the infamous, 'Danish Design'; It is a long standing view that the Danes are leaders in design and quality;
Or so they say.:Cool:
Brian, I am tempted to take your advice ref God. I had cancer in 1992 and also in 1995, and having been given 6 months to live in 1995 and yet I am still here, thats the first reason to believe, 'He sure as h*** ain't ready for me yet'............my second reason shall 'stayeth a hush' for now.
Happy tourings, and thanks for the answers.
Adge
PS, I think the answer can be found within the 23rd Psalm, "My Lord he 'leadeth' me" :pray:
A good set of leads of varying types and polarity
shortcircuit
162
Papa
"and the rcd protection in the van wont work so it wont trip but it will at the hookup pillar"
Are you sure?. It does not matter if the RCD is incorrectly wired as it measures the current flowing in both conductors and looks for an imbalance
tommytli
May 26, 2009
434
26
lancashire
coach built
since july 07
weve come across reverse polarity twice on our travels through europe once in belgium and once in croatia, i soon as i hook up i test the sockets to make sure all is good, on both occations our motorhome corrected the problem within 1 minute on its own, a light comes on the control panel then you here a quiet sound like like a switch flicking and thats it, checked the plugs after and all is well
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I am an industrial strength agnostic but I, sort of, became a believer in Morocco. There the operative phrase is "inch Allah", if it pleases God, and it's the only way to cross the road in Marrakech. You look ahead where you want to go and walk at a steady pace, inch Allah the traffic flows around you and you get to the other side.
JayDee
1,057
169
N. Devon
7 Years after 5 years with caravan.
Not taking the p*** Brian, but this typo made me smile.::bigsmile: Totally in context.
John
lebesset
760
this is another typical british scare story , the risk on this is so low as to be non existant ..you are more likely to kill yourself falling out of your motorhome door
but if you really concerned about this for reasons I can't follow , why not just fit a 35mA trip with 2 channels that both the phase and neutral go through ...must be available in uk one presumes to replace the old fashioned systems , been compulsory in france and probably elsewhere for 20 years ..of course in france you can put power points in the bathroom !
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
The EU is pushing us in your direction. RCBs are standard now but we can't just abandon our strange system of wiring that has been in use for 40 odd years.
We once had proper wiring, when I was a kid all sockets were individually wired and fused, used round pins too.
I wonder if canbus could ever be applied to power wiring ? A 100amp power cable would be the killer.
lebesset
760
don't have to change the system brian , just fit the new [ well 25 years old ] trips or fuses on the DIN bar
in my property I actually have FUSES , remember them ? dual channel though ! not that they ever blow because the whole supply comes through an electricity company 500mA trip and that shuts down first ! not always convenient!!!!
Wupert
23
S Wales and Austria
25 plus
Our M/H tells us if we are on reverse polarity.
We were on three occasions during our recent trip through France
Solution buy a standard French connector for approx £6.50
Swap the wires and mark this connector as RP
Use this connector on RP supplies
Any worries solved.
Wups
