Restring fly screen door on 2015 Flair (1 Viewer)
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
A string has broken on my fly screen door and the whole thing looks pretty dire now. I cannot see how to dismantle it and restring. Does anyone know the make of screen and any online reference to restringing. At Camping Algeria for 2 weeks so if it is complicated is there a local company anyone knows of?
jumartoo
6,991
189,939
Alhama de Murcia, Spain
Hymer Tramp
Since 1994
Is the screen a concertina one with horizontal strings? If so we're also trying to get one repaired. If we get anywhere I'll let you know.
R
Robert Clark
I had the strings go on my Heki roof light flyscreen
Found a video on youtube - might help?
sallylillian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Been looking for solutions on Google but not found anything useful. Have emailed factory but hoping for a "just done it" on here? I am sure it's the same unit as Hymer et all.
sallylillian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Yes exactly. Have identified, I think, to remove complete box but would like to get a how to crib sheet.
R
Robert Clark
On our roof light I managed to stick some felt pads to the sliding part to stop it from moving too easily
Looks like you could do a similar fix on your door flyscreem
R
Robert Clark
Robert what "string" did you use, I am surprised that this has failed after just 12 months so want to do a good job!
Mine went on our last trip
I posted pics of my repair
Will get it replaced next year when I have my next service -
sallylillian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Took off the aesthetic panels and it would seem that the strings are held by pop rivets inside a box section which was also pop riveted together. I am sure on a work bench with the right tools it could be dismantled but that's a test too far here. If @Lenny you think I have missed something let me know.
jumartoo
6,991
189,939
Hymer Tramp
Since 1994
Liked the fact you're getting yours replaced. Not happy that they can't be restrung though. Not good news for any fairly new but out of warranty.
We need a new one. Going to check out with Hymer when we're in Germany in September.
Good luck!
sallylillian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
I think you could restring, getting the frame out is easy and then you need to drill out the pop rivets string and reassemble. Care should enable a good result but I have 2 year warranty so I will let them fit a new one.
jumartoo
6,991
189,939
Hymer Tramp
Since 1994
Problem is we need new netting as well, so looks like a new unit unless they can fit into the original surround.
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
The hab door concertina flyscreen on my Carthago is made by Horrex.
One of my horizontal strings has also broken. I emailed Horrex in Netherlands for replacement cord..... but no reply.
I've decided to do a complete restring using fishing line. The frame will need to be removed to do the restring. The frame seems to be held to the surround by screws in a slotted vertical aperture, so raising the frame should release it from the surround.
I was camped next to a French Burstner MH with the same flyscreen and they managed to remove the screen and carry out a repair to the string system. So, it can be done.
sallylillian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Well factory have come up trumps again. New frame and screen door complete on the way to service dealer south of Alicante. He has availability for us on 14 or 15th so we will drop in after seeing our friends at Altea. It's a simple job probably an hour for someone who has done it before.
deanroofing
297
253
bedfordshire
coachbuilt
since 2010
Ours went on our Bailey had to have a new fly screen fitted at our dealers, the guy who did it was chuffed as he just had to remove the plastic cover and the screen could come out was done under warranty
sallylillian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Arrived Cruz Caravanas early 09:30, they had me scheduled for 10:30. 10:50 into the workshop, 12:00 shaking hands and Adios with a complete new fly screen and frame fitted. Down to Playa Mazarron and on a pitch for a late lunch. Slight tweak needed to ease runner but otherwise better than new. And all under warranty.
Lenny HB
53,431
150,019
On the coast in West Sussex
Hymer B678 DL
A good result.
.Restringing is easy did it on my last Hymer. Took the whole frame out and restrung the broken one with black kelver kite line.
Jul 6, 2016
1,547
1,264
West Sussex
Since 1990
A good result.
Thanks for the tip Lenny. Found braided black Kevlar kite line, 300 pound, on eBay - that should do the job. Was going to use braided fishing line but this looks better.
sallylillian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
But if the frame is pop riveted it's a whole new ball game to restring.
sallylillian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Was screwed together on the Hymer, pop rivets easy to drill out & replace with self tappers or new rivets.
Some of the snowbird Germans with complete engineering workshops on their pitch may, but my simple travelling tools do not give me the confidence, but glad it is possible.
NIB
Swift 686
Thanks Larry HB. I know this post is very old but it still helps. I was wondering what to use to replace my two broken strings your suggestion of Kevlar kite strings was spot on. I ordered some 300lb / 1.5mm on Wednesday and fixed it Thursday. It now works as well as it ever did AND I think it is far less likely to break being Kevlar. If anyone is thinking of doing this it is quite straight forward, just take photos of each stage as you dismantle it. If you want any help just give me a shout out.
Lenny HB
53,431
150,019
Hymer B678 DL
Thanks Lenny HB. I know this post is very old but it still helps. I was wondering what to use to replace my two broken strings your suggestion of Kevlar kite strings was spot on. I ordered some 300lb / 1.5mm on Wednesday and fixed it Thursday. It now works as well as it ever did AND I think it is far less likely to break being Kevlar. If anyone is thinking of doing this it is quite straight forward, just take photos of each stage as you dismantle it. If you want any help just give me a shout out.
I just had to restring the windscreen privacy screen on my current van, it shouldn't go again now I've replaced it with Kevlar.
Jun 8, 2019
4,931
18,760
Bexley Kent
Given up Motorhoming
May 2019
If the dealer says it canā€™t be repaired then ask him if you can have the old one take it home and repair it yourself as a spare.šŸ˜‰
Jun 8, 2019
4,931
18,760
Bexley Kent
May 2019
Looking to the future Lenny šŸ˜€
