Repairing 12.5mm plastic water pipe (1 Viewer)
atakd
106
Wirral
Since '99
We discovered on Saturday night that our water pipe between the pump and the bathroom has split - presumably frost damage though tank had been emptied and taps opened - it's split at lowest point where water collects. As the split is outside the van, inside the rear GRP skirt, rather than replace a 6 metre run of piping I would like to attempt a repair. Has anyone done this successfully? I've used clamps to repair domestic pipes with mixed success but I assume the pressure on the van is lower at 20 psi / 1.3 bar.
TIA
Andy
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
Any caravan shop will sell push fit fittings, a new lenghth of pipe and 2 conectors. I would be looking to replace the whole pipe though as the cost is minimal and you would have 2 less joints.
atakd
atakd
106
Wirral
Since '99
Cheers for that. It's not the cost that bothers me but the effort of having to replace the whole run with what seems pretty inflexible pipe.
sedge
Jul 7, 2009
5,504
13,117
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Can't you coil the pipe into a container of hot water to make it bendy and go where you want it to?
f6c
Nov 7, 2010
10,960
4,793
gloucestershire
Carthago Malibu 640
23 Years
Andy,
Try connecting the new pipe to the old pipe and then slowly pull it through.:winky:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Have used plumbers toffee tape in the past,and it works.Get it from any builders merchants.Just wrap it round the break,burst, and leave it.It never sets hard but is completly waterproof.Always carry some in the RV incase of leaks.
atakd
atakd
106
Wirral
Since '99
Problem sorted. It wasn't a burst pipe but a plug of ice that melted and let the freshly filled hot water tank drain out through the open valve:Blush: If I hadn't been parked in mud at the time I might have spent a bit more effort in diagnosing this. Thanks for all suggestions - you never know when they'll come in handy.
