Removing fridge (1 Viewer)
Jaygee32
145
14
Norfolk
since 1976
Hi, Can anyone advise us as to how to remove the fridge or at least get to the Spark/igniter. It's a Rapido 709f the fridge is Dometic. we went to light the fridge (on gas of course) but the "flasher" didn't work. we've undone the four screws holding the fridge in the cabinet but cant get it to budge. Any ideas please? Or is there a simpler way to get to the back of the ignition?
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Hi you may be able to get to it through the outside lower vent.
You say you have removed four screws ? try looking inside at the top :thumb: I suspect you may not have seen 2 :Eeek: once you have found / undone them it should pull out easy
terry
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
As Terry said, have a look from outside via the external vent first.
I took our out on the first van and, errr, discovered I could have fixed it in situ:Doh:
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
you will have to remove the sink to get to the gas surply pipe also the 12/240 surply?
you cannot just pull it out.
chris
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Check it has not been sealed in place, Mine looks as though it has sealer run round the back (seen from inside the outside covers - if that makes sense) to stop draughts getting in maybe.
J
Jaygee32
145
14
Norfolk
since 1976
Thanks to you all for your advice. Removed back panel and took out 2 screws this enabled release. then disconnected gas pipe. Checked all wiring with meter all OK. Tried again and it worked. Replaced everything, went to light it again and nothing! :swear:Then a little light bulb switched on in my head. A few days ago the selection knob(elec/batt/gas) had somehow fallen off. We had pushed it back on not giving another thought, :Doh: but yesterday on closer inspection we found a small split where it fits on to the "spindle" thus it was slipping slightly and not stopping where it should. We turned it with a pair of pliers and Bingo. Lesson learned. All we need now is a new knob.:thumb:
cornishaich
240
5
West Cornwall.
A year.
quote [All we need now is a new knob.] quote
:cry:There are a few of us out there who could do with one of them:cry:
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
J
Jaygee32
145
14
Norfolk
since 1976
new knob
It's a little grey one with a pointer on!
ubuntu1
155
44
Derbyshire
PVC
since 2006
Its really important that you know what your doing when removing a fridge. For example some fridges have to be room sealed to prevent carbon monoxide and fumes entering the van.
When you put it back you must test for gas leaks. I do this as part of my job and even I get leaks sometimes.
By all means work on your own vehicles but please take care with gas.
