Regulator s (1 Viewer)
rich g
480
855
Worcester
A/S Warwick
since 2013
My regulator between my battery and solar panel has packed up after only 4 months,,Two questions 1,what could cause it to fail faulty reg or something else ?
2,I don't know the output of my solar panel does it matter what regulator I fit ?
Thank
andy63
4,672
15,017
south shields
None
since 1990
Thank
When you say your charge controller has packed up... how??
Have you tried re booting so to speak... ie switching it off or disconnecting and then starting from scratch... making the connection to the batteries first before connecting the panels...
Check the no load voltage from the panels as well to make sure all is in order there. .
If you have to replace it it will have to match the power rating of your panels ie be capable of handling the max voltage of panels and the current. .
Post a picture or give details of the present controller. ..and your panels
May help people advise...
Andy
funflair
19,363
30,276
Guisborough
MORELO palace
since 2012
Thank
What would cause it to pack up? Don't know assuming that you only have one panel it should not have overloaded the regulator, what make was/is it.
Your panel should be a nominal 18-20 volts (you could check this with a voltmeter) most regulators will handle that, if you are spending money go for a MPPT and if there is any chance that you might add more solar get one big enough to handle the lot.
Martin
SandraL
1,373
985
Somerset
Hymer b694sl
Perhaps the order of connection?
I believe it is usual to connect battery and then connect solar panel. If disconnecting then remove solar panel first and then dis onnect battery.
Whether doing in wrong order will actually damage the regulator i do not know.
rich g
rich g
480
855
Worcester
A/S Warwick
since 2013
I will phone AutoSleepers they fitted it,and maybe it is under warranty :):)
