Refillable gas tank fittings (1 Viewer)
Gazza333
592
244
Staffordshire
Rollerteam 695
hi
I've just come to fit my two gas it bottles complete with external fill point. Now my external fill point is one of the removable 90 degree types as this suited my installation better. I positioned the external fill point in the side skirt and measured it such that I could use a fill bracket to make it sturdier if need be.
Everything went great right up until I came to fit the refill pipe. Now the hole in the gas locker and the 90 degree on the fill are about an inch apart and as the fill point is so close to the gas locker the pipe won't bend to fit
So I could move the fill point but then I'll have a hole in the skirt to show how stupid I am. Or I need some form of dog leg fitting to go between pipe and fill point.
What thread is on the fill points? Is this the 21.8 lh I here about? Maybe I could fit a t piece and blank off the unused bit of the t .
Anyone help before I have to own up to the wife I cut the hole in the wrong place ?...
Jul 13, 2008
3,739
3,874
Low profile
Put another hole in the gas cupboard floor?
G
Gazza333
592
244
Staffordshire
Rollerteam 695
G
Gazza333
592
244
Staffordshire
Rollerteam 695
The hole is in the gas cupboard side wall and is as close to the edge as I can get.
I suppose I could buy a fill hose with a 90 degree end to it and swap my angled fill point for a straight one. Looks like that would do it. £50 mistake though. Suppose I could sell the other ones though
Jul 13, 2008
3,739
3,874
Low profile
Can you not put another hole here?
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
So you want 2 x 90degree bends, or speak to GASit and they may make you a custom pipe? Or turn the brass elbow 90 degrees clockwise and refit, should use same screw fixing, then a pipe with a 90 elbow instead of straight??
Minxy
32,659
66,566
E Yorks
Carthago Compactline
It really depends on how long your hose is ...
I you have excess pipe length then turn the fill point 90 degrees and put a large loop in the pipe then connect it up, alternatively you could loosen the filler, fit the pipe then re-tighten the filler so long as it all goes back okay without undue strain on the fittings. If not then put a hole in the bottom of the gas locker and then turn the filler a quarter towards the direction of the 'camera' and fit that way.
G
Gazza333
592
244
Staffordshire
Rollerteam 695
the picture is a little deceiving. the fill pipe needs to be 1 inch more towards the skirt which it cant go as im already at the front face of the gas locker. It looks like boringfrog has a simple solution but its an illusion if idid tha id be two inches away . the pipe really needs to move 1 inch lower in the pic. or alternatively the fill port grow an inch if that makes sense.
Minxy
32,659
66,566
E Yorks
So if I understand you correctly putting the hole directly in line with the filler connection would still mean that the pipe couldn't be bent sufficiently to meet up. How long is the pipe and could you do as I suggested earlier?
Minxy
32,659
66,566
E Yorks
If all else fails move the filler to the correct location and buy a couple of large orange reflectors, one to cover the mistake and the other in the same position on the other side and hope the wife doesn't notice ....
Aug 18, 2014
23,786
133,732
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Slot the existing hole right through the metal frame (?) towards the front. Or a sminxy said if hose is long enough turn fitting down or up & drag out the excess hose & make a loop .
Minxy
32,659
66,566
E Yorks
Link Removed
Link Removed
G
Gazza333
592
244
Staffordshire
Rollerteam 695
Yes. The hole is actually directly in line with the fill adaptor. Just an inch above it. The hose isn't long enough to loop but I think it would be much better to buy a new straight fill point and a fill hose with a 90 degree end . More expensive I agree but I'm guessing it will be a permanent fixture for quite a few years so maybe better to do it right now or I'll be forever thinking I bodged it
Jul 13, 2008
3,739
3,874
Low profile
Another thought too. If you're running gas pipes though any holes it might be a good idea to use a @Gromett to stop the pipe "chaffing".
sorry @Gromett ;)
Minxy
32,659
66,566
E Yorks
Or just turn the filler down, get a longer hose and put a loop in. This would also mean that if any grubby stuff is in the lpg it would settle at the bottom of the loop too.
G
Gazza333
592
244
Staffordshire
Rollerteam 695
sorry @Gromett ;)
Good point I'll google some to see where I'd get one from. I have a 29mm hole that the pipe only just fits through so can't imagine it moving much but I see your point
G
Gazza333
592
244
Staffordshire
Rollerteam 695
Another good idea but then the loop would be dangling down near the road .
I appreciate all the comments though as it's making me think . Just goes to show one small mistake causes no end of problems
Minxy
32,659
66,566
E Yorks
Alternatively use sealant to make a 'grommet' as this will also keep it from moving about too.
Minxy
32,659
66,566
E Yorks
... this is a fine example of what happens when (some) men do DIY .... :rofl:
Dec 12, 2010
5,414
21,581
Cumbria
since 2011
I'd do similar to what Minxsy suggests, turn the fitting 180° and fit a longer hose with a loop in it, you could put a saddle clamp over it like the electrical cables that are fastened to the floor in your pic. Fitting extra elbows on to that type of fitting might be a nightmare to seal or line up as they are designed as taper seating closures, not thread sealing types.
G
Gazza333
592
244
Staffordshire
Rollerteam 695
I have the saddle clamps too. So maybe a cheaper option to buy a longer fill hose. Any idea how much longer I'd need to form the loop ? I currently have .75m which is just long enough to reach as shown n pic . I'm thinking of 1.5 m to make sure it's long enough to form the loop. Does that sound right?
I've emailed gas it as well
G
Gazza333
592
244
Staffordshire
Rollerteam 695
Reverse engineer it. Disconnect the hose, turn the fitting 180°, connect the hose to the fitting, put in a loop and see how much hose you have left when it reaches the hole you made. (y)
Your far to clever for me . Never thought of that sitting in my nice warm living room. I'll take a look when it's light.
Dorset wanderer
56
78
Blandford Forum
Geist Liberty Low Profile
since 2007
Can you turn it upside down and then use two 90 degree f/m elbows, job done
Lenny HB
53,448
150,065
On the coast in West Sussex
Hymer B678 DL
We have all done things like that for the sake of peace of mind and a few quid you know it makes sense to do it properly.
Problem is if the hose is too long very difficult to loose the excess as the hoses are so stiff.
G
Gazza333
592
244
Staffordshire
Rollerteam 695
Well I purchased a longer fill hose. Turned the fitting 180 degrees and made a nice loop secured to the underfloor. All looks great now. Just need to fill up now to do final check
Minxy
32,659
66,566
E Yorks
Where's the photos then! :D
