Red light on truma unit- help!
Discussion in 'Motorhome Chat' started by Branston1080, May 5, 2014.
  1. Branston1080
    Branston1080 Funster
    Oct 30, 2012
    54
    32
    A red light is showing on the truma unit. It normally comes on when the gas is empty but the gas is fine.
    I ran the van engine as its been stood for a while on site. I turned the electrics off before hand but forgot to turn the truma unit to off. The red light is now on.
    Have I damaged something?
    Any suggestions welcome.
  2. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,576
    10,004
    red light is normally a flame failure warning. could be a few things, but try cycling it on and off a few times to rule out an airlock in the gas supply
  3. maz
    maz Funster
    Jan 26, 2011
    2,536
    2,174
    Out there somewhere
    If it's the same Truma as mine (Combi 4E/6E) a red light will come on if the 240v supply to it is interrupted. Switching it off then on again at the control panel resets it. If there's a fault the red light will be flashing. HTH
  4. Steve
    Steve Funster Life Member
    May 8, 2013
    1,576
    1,852
    Compton Berkshire
    you haven't left the exhaust cover on have you. I often forget about it myself.
    Steve
  5. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,068
    2,938
    Essex
    red light
    You may have to leave off for a while before switching on again. May be 30minutes.
    check the instructions or try and get them online if you can.
