Recommendations for a 12v compressor? (1 Viewer)
Touchwood
772
733
NE England
Compass Avantgarde 140
5 years and learning
Away in the Lakes earlier this week I spotted one of Jim's LED tyre pressure monitors flashing away - sure enough when I checked the pressure was down significantly. To add to the potential problems I found I've lost the keys for removing the LED's, but managed with a pair of pliers. Changing to the spare on a Boxer is a nightmare for one of my advanced years and somewhat portly build, so a friend who was also on holiday in the Lakes was contacted and brought his 12v. compressor, only to find it wasn't man enough for the necessary 65 psi I normally run at.
At the end of the day it wasn't a problem - there was still about 40 psi in the tyre so a careful drive to a garage in Keswick and we pressured up there - but it occurs to me that a 12v. compressor that is man enough would be a wise investment - any recommendations?
TheBig1
17,630
43,277
i picked up a genuine fiat one brand new on ebay for under £15. it does the job but slowly and a bonus is it comes with the bottle of glue to fix a puncture temporarily. fiat specify this as an option on vans with no spare tyre so it must be deemed ok by them
in preference I would prefer to replace my T-max offroad compressor. a bit bigger but certainly up to the job with ease
geo glasgow
292
274
Glasgow
Auto-trail cheyenne
Touchwood
Touchwood
772
733
NE England
Thanks to all - the RAC900 certainly looks the biz - but the Nikkai from Maplin's (as recommended by Southampton) is a lot cheaper and since I'm only looking for an emergency backup I fancy one of those - unless anyone has a bad experience with one?
2657
Second vote for Ring RAC 900, bit expensive but very good, crocodile clips much better than cigarette lighter socket.
For larger tyres the airflow capacity is more important than the claimed max psi.
Most smaller/cheaper compressors would probably burn out before they got anywhere near 120 psi except maybe on a baloon ::bigsmile:
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
I have a Ring RAC600 which I bought a few years ago having seen a test report in a magazine.
I still have my Ring RAC600 from the days when I used to pump up my car tyres, but it's not man enough for the pressures needed on my van. A motorhome workshop reckoned they could use one of these to inflate my van's tyres. I'd already tried it and knew otherwise, but I let them go ahead. After they'd allegedly got them to the correct pressures I brought out my digital tyre pressure gauge - and, of course, they were well down on what they should be. Then I fished the RAC900 out of the locker. ::bigsmile:
Southampton
522
318
Hampshire
Since 2009
Quote....Most smaller/cheaper compressors would probably burn out before they got anywhere near 120 psi except maybe on a baloon ......unquote
I don't disagree, but I only use it upto 65PSI max 80, and it does the job perfectly. Even checked it against a digital tyre pressure gauge for accuracy. Can't comment on the Ring 900.
Emmenay
505
481
Swift Kon-tiki 600
Since 2011
As well as a compressor I carry something similar to this as a last resort.
Broken Link Removed
43,329
49,444
I have the Maplins version and recommended it a couple of years ago.
mine has been relegated to charging a small (25ltr) air tank to 115psi for airhorn use but managed quite well inflating my tyres to 80psi before i relegated it.
2657
Sorry, didn't word my last post very well. I wasn't knocking the Maplins or the Rac 600 as I have no experience of these. My comments were aimed at the cheaper end of the market ( I have used)which tend to be OK for occasional use on car/small tyres but struggle on anything the size of a motorhome tyre.
GJH
29,450
38,827
None, now sold
2006 to 2022
The rear tyres on our van take 5 Bar (72.5 psi) with the Michelin Camping tyres which were on it when we bought it. The RAC600 copes OK with that :Smile:
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
I have the RAC600 which pumps my tyres up OK and also pumps my air suspension when required. Small and easily stowed. :thumb:
Dec 10, 2013
3,423
12,224
South Staffs
Pilote P740GJ
Since 2013
Hope you don't mind me hijacking this thread but does anyone know of a compressor with a push/pull fitting for the tyre valves as my motor home has twin rear wheels and i can only pump my tyres up at our local petrol station. :Smile:
karl c
231
247
Lincolnshire
since 2010
get some Tyre valve extensions.
