Radio interference when using other 12v devices (4 Viewers)
MattR
4,105
38,897
Beds
Panel van
Years
Greetings.
I seem to be having interference problems with our FM radios whenever I plug in my 12v charger for my dash cam. I have the same issue when I use my wireless reversing camera - I had thought that it was the wireless signal but I think that the interference only occurs when I have the monitor plugged into the ciggy socket.
The interference reduces the signal strength of the radio and causes it to do frequent scans to look for a stronger signal.
Any suggestions on how we can deal with it?
I've thought of running a power supply from the LB to the front of the van so I can power the SAT NAV & reversing camera monitor in case the interference is linked to being on the same power supply as the radio but 1) I would rather not have an extra wire running through the van unless it is essential & 2) I fear that the problem is based on interference with the radio waves so that the circuit is irrelevant.
Jan 17, 2010
262
348
Northants
Bailey Approach740SE
Since 2006
Nothing you can do apart from buy a better quality 12v adaptor.
Try getting a known brand of 12v usb charger which is CE marked. It's a bit of a minefield but the more you pay the better the screening of the radio frequencies that these power supplies generate. Belkin seemed to work for me
MattR
MattR
4,105
38,897
Beds
Panel van
Years
If I wrap the chargers & cables in tin foil, will that help until I can get better chargers?
Jan 17, 2010
262
348
Northants
Since 2006
Might do, depends upon whether it's conducted or radiated, Ive never actually tested my bad ones yet, the tin foil needs to be earthed though.
Jan 22, 2013
1,254
60,361
London SE
A class Adria vision I707
since 1971
A twisted pair running from the leisure battery through a choke will reduce a lot of interference, but your protagonist the camera/ 12 volt to 5 volt charger should be looked at first, try and keep the wiring apart and also try to run your aerial lead separately from all existing wiring,
I have just changed my rear camera to a twin wired one, it gives me a better picture without getting a bleed in picture from other sources, at the time I had presumed it was the main culprit for my poor radio reception,
But the main problems will be quality of radio and aerial, good quality doesn't come cheap, :thumb:
karl c
231
247
Lincolnshire
since 2010
some chargers have pore EMC on them. They give of RF witch will mess your radio up.
CE mark dose not mean any thing as they get the CE on the first paten then cut back on the parts.
you could try a ferrite ring around the cables.
Broken Link Removed
43,331
49,467
could be a poor earth on the radio aerial or the radio itself.
Will still work ok but wont be fully shielded against spurious RF interferance
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
I have same problem in my Audi.
If I use rear demister, radio goes shit.
Thats probably where the aerial is.......2 vertical lines built into the rear window element
Again could be a bad earth on the heater elements causing it to earth through the radio.
