Question for physisists/gas experts (1 Viewer)
Jun 22, 2011
507
1,305
Onchan, Isle of Man
Carthago
Since Nov 2010 after 25 yrs under canvas.
We have a cadac with a very long gas cable which we attach to the exterior gas point on our Globecar campscout. This works very well.
My wife has suggested that the cable is too long and if we shorten it the heat will improve. Her thinking is that as the gas has less far to go it will have more pressure. I disagree.
Anyone here able to give a definitive answer?
Dec 13, 2013
58
41
peterborough
a class
just started
I can't quote the exact law but there is certainly friction from any liquid or gas through a pipe. I think that there is a maximum length of pipe suggested in the Cadac instructions.
DBK
18,029
48,099
Plympton, Devon
PVC, Murvi Morocco
How long is very long? A couple of meters will be fine. As mentioned, the pipe is an obstruction and there will be some loss of pressure, but it will be quite small unless the pipe is extremely long.
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
As the gas is flowing then it will be subject to internal pipework friction and a reduction in pressure. Whether or not it will make a noticeable difference to cooking temperature will be more down to the size of flame, rather than a lowering of the heat that the gas burns at.
funflair
19,363
30,274
Guisborough
MORELO palace
since 2012
Well at the risk of being pedantic, the pressure is the same no matter what the length of hose as long as the exit is turned off, BUT it is the volumetric flow that will suffer relative to internal losses and this indeed could cause some perceived loss off pressure BUT relative to the demand of the Cadac (more gas flow less pressure) will it make a difference over a few metres? I doubt it.
Martin
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
Just adapt an old fireman's hose... bigger cross section; then you can park up in France and BBQ in Spain... (y) :rofl:
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
As per 'funflair' - although I suspect that the pipe is of more than adequate cross-section for its intended purpose so the pressure will be the same at both ends. The burner jet internal diameter is minute compared with that of the feed pipe.
May 29, 2013
2,598
19,237
Tyneside
Chausson best of Flash 10
Several years now
The "heat" of the flame is down to the calorific value of the gas supplied. Don't know if the value for Butane or Propane is declared on the bottles ?
But for domestic gas supply each area of the UK may have a slightly different calorific value to another and if you have a high calorific value your kettle will boil faster. Tho the difference will be small. And your gas bill is adjusted for how "good" the gas is !
The "size" of the flame may get smaller on a really long pipe run, but doubt 4m will affect it at all.
Dec 23, 2014
2,178
2,818
South Somerset
Carthago C-Line I 50
Since 2009
Been using a 5m length on our cadac since 2009 without problems. Frankly ours gets too hot and is never used above the minimum setting. If you want more from it up-size the jet.
Mar 23, 2012
9,548
32,104
sleights
c class
If as you say it works very well why ask the question!!!!! (and remember whatever the question your wife is right)
Stretto Boy
1,503
306,682
Leicestershire
Since 2011
The Wino is right : ignore the experts (who are of course correct), tell Mrs Manxcat that as always she is right, get out your pipe-cutters, comment on the remarkable improvement in the performance of your Cadac and enjoy the lovely meals that your wife cooks for you on it. Result happiness! :D
May 31, 2015
11,684
44,533
Cornwall
Ducato PVC
Getting Better
Gas in my house comes all the way from the North Sea and I've still got pressure .....:D2
43,331
49,466
Won't make any noticeable difference over such a short length.
How far is it from the Russian gas fields to the UK ?
Gas doesn't suffer the same flow restrictions of, such as, water in a pipe.
Consider how far gas has to travel around your house.
Jan 28, 2008
10,117
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
standing pressure will always be the same its working pressure of each appliance thats affected by the length of the runand your wife is right the longer the hose the less working pressure you will have whether its discernable is another thing
