Propex Malaga 4E-Diagnostics
Discussion in 'Heating and Air-Conditioning' started by yellabelly, Feb 23, 2015.
  1. yellabelly
    yellabelly
    Feb 19, 2015
    56
    66
    Lincoln area
    Hi all; We have a Propex Malaga 4E water heater that to be honest gets little use.
    However; for the last couple of months it's been "winking at me" i.e. the diagnostic light has been flashing 3 times then pausing.
    Apparently this means there is either a low or high supply voltage to the unit. Just what that might entail I have no idea, so thought I'd ask.
    I've drained water from the whole van so haven't tried to test whether or not the heater will fire up.
    The leisure batteries are regularly charged up over winter, and the battery level indicator is at "normal". The gas supply is not turned off.
    I'm tempted to just take it up to Mick at Countryside Motorhomes before we use it next, but thought I'd ask if anyone has any suggestions, (I like to try to understand these things).
    Is it maybe just a "lockout' that I need to clear?
    Regards,
    alan
  2. JJ
    JJ Funster
    May 1, 2008
    14,641
    25,978
    I might be completely "off track" here but will the boiler work with no water in it?
    I don't think my Malaga3E does...
    JJ :cool:
  3. yellabelly
    yellabelly
    Feb 19, 2015
    56
    66
    Lincoln area
    That could be it JJ, but the manual doesn't mention, which is a bit surprising.
    I believe that the 4 can't be lit if say the boiler had been damaged by frost. We had that happen a couple of years ago!
    cheers
    alan
  4. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,048
    3,450
    walthamstow east london
  5. yellabelly
    yellabelly
    Feb 19, 2015
    56
    66
    Lincoln area
    Propex say that Malaga has experienced a high or low voltage, so I must do the reset procedure.
    I'll leave it until the next trip.
    Thanks for input
    alan b
Similar Threads
  1. jezport
    24
    780
