propane or butane (1 Viewer)
JockandRita
11,462
150,163
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
which gives the best heat, propane or butane, have one bottle of each so want to get two the same, thanks
Propane gives of a hotter flame, and, it still gasses off at temperatures below freezing, whereas, Butane can't. Ideal for all year round usage. :thumb:
Cheers,
Jock.
DBK
18,029
48,100
Plympton, Devon
PVC, Murvi Morocco
At low temperatures propane. If you only ever go out in summer then either will do, but propane is what you want for the colder months. Butane will stop working when it's cold.
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Butane is denser, and I believe actually produces more heat per litre. However as previously stated Butane is of limited usefulness in cold weather as it will not vaporise so no gas.
For motorhome use, Propane is the one you want, or of course a fixed/refillable tank with autogas.
Nov 13, 2012
440
438
Somerset
coachbuilt
since 2000
Butane
I put bubble wrap round my gas bottles and they worked fine down to -9C:thumb:
Nov 18, 2011
11,862
43,044
Planet Earth
A van
Over 25 year's
in my old van I just run sum heat from my blown air through the locker just a small pipe run through it worked down to -10
and never had a problem with gassing of ::bigsmile:
Apr 27, 2008
11,842
14,071
Hymer low profile
Since 1972
Obviously you know what worked for you however as gas turns to vapour it will absorb heat (latent heat of evaporation) from its surroundings, so insulating a gas bottle will make it colder, not warmer. Simple physics.
Rapide561
471
167
Leeds and Lake Garda
Propane
My own view, and indeed choice, is to use propane as it is good for all year round use.
There are differences between the cost and efficiency of the two products - here - if you want to know more.
Russell
