Problems with Card Reader (1 Viewer)
Bulletguy
2,043
8
Cheshire/Staffs
Having recently replaced my hard drive with a brand new one and installed XP Pro from fresh, for some reason i'm having problems offloading photos off my USB Card Reader.
It's one of those multi card readers that take CF cards and Memory sticks, both types of which i use.
When i open the files > Select all > Move to folder....i maybe get a couple off before the damn thing crashes and i have to go through the whole process again.
I've also tried offloading from the sticks/cards via ACDSee but that didn't make much difference either.
Only way i can get them off is one at a time....which makes it a bloody long job if i've shot off 50-100 photos!
Tried using different usb ports on my pc but that also hasn't solved it. Though its just a cheap reader off eBay, i never had this problem before until now.
Any ideas anyone????
2,345
10,185
I had the same problem a few months back, but reformatting the hard drive solved it ..
have you tried re installing the reader's driver ?
sorry can't offer any other advice.. :Sad:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Software drivers for the card reader must be available from the manufacturer of your machine rather than a plug and play driver.
dylan
4,110
566
sw wales
none
n/a
Hi Bulletguy, I use similar card reader from 7day shop.com and installed Adobe photoshop album starter edition 3.2 and it just does everything for me if I have a bulk amount to download. Download free from here Adobe - Adobe Photoshop Album Starter Edition 3.2
It may get you over your problems for the time being. :thumb:
S
sinbad1
Has this happened since the new drive was installed ?
Have you tried the card reader in another pc ?
If the card reader works in another pc then there could be usb issue, first remove all other usb devices and try again.
You could try removing all usb devices under usb controllers.
then rebooting ,letting windows reassign devices.USB Controller section
3. Right click and Uninstall all of the listed USB devices
Also
Go to Start>> Right click My Computer>> Manage>> Device Manager
expand universal serial bus controllers
and check for any yellow exclamation marks ?
Douglas
2,835
400
South Wales,
Have you been removing the memory with out unmounting it?
If so you may have to use the camera to read it into the computer via a usb cable, when you have done this and the photo's are safely on the computer then use the camera to reformat the memory to stop it happening again
Doug...
B
Bulletguy
2,043
8
Cheshire/Staffs
Afraid thats all it is.....PnP. No software or driver came with it, just the reader.
B
Bulletguy
2,043
8
Cheshire/Staffs
Doug...
Not quite sure what you mean by "unmounting" doug, but i've never used the camera to read direct into pc or for that matter ever had to reformat either stick or cf card.
B
Bulletguy
2,043
8
Cheshire/Staffs
I'll have a look and give this a go Dylan.....thanks.
B
Bulletguy
2,043
8
Cheshire/Staffs
Also
Will have a look at this sinbad.......thanks.
Douglas
2,835
400
South Wales,
Ok, on the bottom left you see a collection of icons (I assum XP, Vista may be different), you may need to key the < symbol in a blue circle. You are looking for a green arrow pointing left and down. But your curser on that icon and it will say "Safely remove hardware" with your curser on that Icon press you right key, follow the suggestions.
This will unmount the removable memory/hardware and in so doing stop accidental corruption of the memory.
Doug...
Jun 18, 2008
1,588
2,281
Lancaster
Since June 2008
Doug...
Should that be Bottom Right?
