Power required for battery charger (1 Viewer)
Ivory55
6,017
14,537
North West Norfolk
Since Feb 2012
what size generator would you need to power a stand alone battery charger for 350 amp battery bank using something like c tek 300 to 500 amp charger. Cheers
43,423
50,186
300amp to 500amp.... Typo?... A large arc welder runs at a couple of hundred amps.
30 to 50amp maybe but even that sounds big.
It depends on the chargers input watts, not the output amps.
You would only need a very small genny.
A 600watt 2 stroke would be more than sufficient but noisy.
TheBig1
17,666
43,555
honda eu10i nice and quiet and 1kw output should suffice
Minxy
32,725
66,819
E Yorks
Carthago Compactline
I suspect it wasn't a misquote ... I hear he's a descendant of 'Dr Frankenstein'! :eek:
Ivory55
Ivory55
6,017
14,537
North West Norfolk
Since Feb 2012
I just wondered if it would charge the batteries quicker then the standard Sargent charger so the generator would need run for so long. Cheers
Apr 27, 2016
6,932
8,096
Manchester
A class Hymer
Since the 80s
To find the maximum recommended charge current for 350 amp-hours of battery capacity, just divide by 5, so that's 70 amps.
If they are discharged to 50%, then you will need to put back 350/2 = 175 amp-hours. At 70amps, that's 175/70 =2.5 hours. At 50 amps it's 175/50 = 3.5 hours. In reality add at least an hour, because the charger slows down after 80% full.
I don't know what the Sargent charger rate is, but I guess it's less than 50 amps.
Apr 27, 2016
6,932
8,096
Manchester
A class Hymer
Since the 80s
To find the power required, first find the amps output of the charger. Then multiply by 12 (volts) to get the power output. For example, a 20 amp charger will be outputting 20 x 12 = 240 watts.
Then add about 10 or 20 percent for efficiency losses. For this example that's 24 or 48 watts. so a generator with an output of 300 watts will be OK for this job.
Downside is, at 20 amps it will take 175/20 = 8.5 hours to charge up the batteries from 50%.
If it's 50 amps, that's 600 watts, so a 750 watt generator will be OK. As above, that will take 3.5 hours.
43,423
50,186
