Power Problems with Fiat Ducato
Discussion in 'The Beginner' started by syranara, Oct 1, 2008.
  1. syranara
    syranara Read Only Funster
    Aug 15, 2008
    74
    Northfleet, Kent, UK
    Hi there can anyone give me any advice on our Dethleffs Fiat Ducato that we recently bought. It is an old motor (1990) and we took it out for the first time last weekend. My husband has been checking it out up to now and making sure it had new cambelt etc.
    The problem we discovered on a run though was to do with the power. For the first about 7 miles it has hardly any power and God help us if we have to go up a steep hill! Then all of sudden we get a surge and from then on it flies along.
    Anyone got any ideas please? It has a solar powered leisure battery inside and also a second leisure battery in the engine - could it have anything to do with the second leisure battery or is it just one of those things with this make?
    Apart from that our first trip was great.
    Many thanks,
    Marion
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,265
    5,250
    East Sussex 01-580-881288
    Hi,
    If it is a diesel, check the fuel filter, might be full of crap or water.
    Peter
  3. syranara
    Aug 15, 2008
    74
    Many thanks for that advice my husband will take a look at that. Incidently we passed you on our first trip but it had started to motor then so we couldn't stop :BigGrin:
  4. ourcampersbeentrashed
    ourcampersbeentrashed Funster
    Apr 19, 2008
    7,652
    4,284
    East London
    This probably isnt much of a help but our old 88 highwayman was a 2 litre petrol and we found it really didnt like pulling up hill our 90 bedoiun is a 2.5 litre diesel and pulls fine.
  5. Phil
    Phil Read Only Funster
    Oct 21, 2007
    226
    Herts
    What you describe is fairly normal if it's a Turbo Diesel. My 1993 Ducato surges forward as the Turbo speeds up when the throttle is opened to go up a hill. it takes a few seconds to become fully effective as it works off the exhaust gases. Along the flat or downhill with little throttle opening the Turbo is not providing extra forced air into the engine inlet.
    Phil.
  6. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    I had the same problem with a Diesel motorhome and it turned out to be water in the Injection Pump.Drained and changed the fuel filter and bled the lift (fuel) pump and (in this case) mechanical injection pump through and it was ok.
    You don't mention any excess smoke from the exhaust?
    Has the injection timing been checked out?
    Steve.
  7. syranara
    Aug 15, 2008
    74
    Hi all many thanks for your replies. I forgot to say it is a diesel but not turbo and there is no smoke coming from the exhaust. Thanks American Dream for the mention of water - hubbie knows what you are talking about and will take a look in the morning.
    Thanks again to you all for your advice. Will post and let you know if we fix it.
    :BigGrin:
    Marion
  8. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,265
    5,250
    Hope the speed cameras were not working!!!:RollEyes:
    Peter
  9. Dawn
    Dawn Read Only Funster
    Dec 7, 2007
    190
    Merseyside.
    Hi,
    If you still have problems after checking all the above, it might be worth having your injectors cleaned & recalibrated,
    As you might have 1 thats not opening up properly until the engine warms up.
  10. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Very good point Dawn.:thumb:
    I forgot to mention I did put a bottle of injector cleaner through it.Did invest in a set of newly built and calibrated injectors though afterwards.
    My non-turbo diesel was hard work getting up to speed and keeping "on the boil".
    That's a fair load it's pulling.What power output is the engine rated at?
    Steve.
  11. syranara
    Aug 15, 2008
    74
    Update of Power Problems
    Hi all,
    My OH got time to check the diesel filter at the weekend and I think it was an original :Laughing:
    £10 Halfords soon replaced that and it seems to be running better now. Won't know for sure until we can take it on a long run but the state of the old filter certainly didn't help.
    Oh and he changed the horn as well - got fed up with the little beep beep.
    Thanks to all for your advice.
    Marion
  12. motaomer
    motaomer Read Only Funster
    Jun 18, 2008
    9
    hampshire
    no power
    hi friend had same problem found 2 b fuel tank rusted ( top of tank ) it was worst when wet just thinking geoff & lyn :thumb:
  13. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Crikey Marion,
    If it was an original it really should have been changed as a normal service routine.
    Best keep a spare for the next one.I changed mine on the last van and was suprised how much C**p there was in it.:Eeek:
