power keeps tripping on 12v (1 Viewer)
stephen nicholas
south wales
fiat ducato lunar A630
FIAT DUCATO LUNAR A630
Hi guys my power keeps tripping on 12v the batterys are good and showing good strong power on the control panel inside the cab but it keeps tripping but the fuses never trip just the on button on the main control panel inside the van anyone help please cheers steve
Apr 12, 2010
4,810
51,795
Bury St Edmunds, West Suffolk
Weinsberg Cara
since 2007
There is a short somewhere. When I have had this sort of problem I have disconnected stuff til the culprit is found.
The water pump could be the obvious choice.
The easy way would be to get it checked out by an Electro diesel mechanic.
Phil
Bluestar
279
164
Brighton
Class
10 years.. On and Off
Just a few ideas,
Is the main switch a earth leak switch? if so would trip if any of the power side is leaking /shorted to earth.
The switch itself could be faulty.
If you pull the fuses and replace them one at a time or disconnect circuits till there is no trip then re instate them one at a time to isolate the problem.
Let us know how you get on.
ASel
32
32
Gretna
What is actually tripping?
Normally 12v protected with fuses.
