I recently bought a Jackery power bank (240) to help run off grid for the odd day ‘ weekend, This led me on to install a 100w solar panel to assist with charging the leisure battery and to recharge the power bank.
I planned on wiring the solar panel into a Victron 75/10 and when I needed to divert the solar input to my Jackery I would unplug the Victron 75/10 and plug in my Jackery power bank. The Jackery has a built in solar controller so cannot run via the Victron mppt controller Hence, having to unplug and plug in the Jackery lead to the solar panel rather than hooking it up to the Victron 75/10.
To do that I was going have a pair of MC4 connectors in line, between the solar panel and the Victron. However, I have read in various places that it is unsafe (dangerous even) to unplug MC4 connectors under load. This can lead to electrical arcs and fire etc.
I’m now a bit stuck and need some advice from anyone that’s solved this issue of possible? Here are the scenarios I think I have:
1. T off of the solar cables and plug in my Jackery lead (it’s a two MC4 lead into a DC 8mm Jack). Would this work? / be safe to do? I would leave this permanently connected the the 8mm Jack free to plug into the Jackery power bank? After all, the Jackery is capable of plugging directly into a solar panel without isolating the panel?
2. Buy an isolator and fit it between the solar panel & the MC4 connectors. I could then isolate the solar panel and disconnect the MC4 connectors and hook them up to my Jackery lead. Downside is that the available DC isolators that can cope with two poles (for the negative & positive cables from the solar panel) are quite big and expensive.
3. Charging the Jackery from the 12v circuit (the leisure battery) will take far longer than directly from the solar panel. But ultimately, I could do that - just wire the solar panel to the leisure battery and negate the issues of how to plug the Jackery into the solar circuit.
any ideas anyone?
any ideas anyone?
