Please help...... (1 Viewer)
Dereckerick
236
136
Merseyside
Hello All..
Im hoping for a bit of help
I noticed a little leak from the winter drain plug on the hot water fume vent, so i thought i'd remove it and put a new oring on.
Its fairly new to me and it appears its not been off in some time, anyhow, the bloody end has sheared off the top of the plug and the remains are still threaded in!!!!!!
What am I to do? how can I remove the bit of still threaded in plastic ???
43,331
49,467
a large screw driver and a blowtorch.
heat the driver 'til VERY hot......dull red.
very carefully push the tip into the plastic bung without moving the blade about and making the hole larger.
allow to cool completely then carefully turn the driver.
it may help to run the boiler for a short while to expand the casing but make sure you turn on a hot tap with the pump turned off to relieve the pressure in the boiler.
Dereckerick
Dereckerick
236
136
Merseyside
You Sir are an absolute diamond!!
I had to nip to my dads to get my blowtorch, it must have took all of a minute to do once I had the tools!!!!
You dont know how grateful I am:thumb::thumb:
I just want to check though, when I get the replacement plug, do I have to bleed the system using said plug or can I just put it in and fill it up?
Dereckerick
Dereckerick
236
136
Merseyside
Anyone....please....:Blush:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
If as you say its a drain plug, its going to be at the lowest point in the system
you canot bleed from the lowest point, it has to be the highest, and if were talking about the same thing that will be your hot Tap:thumb:
Geo
Dereckerick
Dereckerick
236
136
Merseyside
Geo
Ahhh, logic evades me AGAIN!!:Doh:
Its better to ask I suppose, thanks Geo.
43,331
49,467
its a pleasure Nick.
we all like to help if we can:thumb:
just put the new bung in and fill it up...bleeding through the hot tap 'til water runs without bubbles/splurting.
be very careful when you fit the bung......the 'O' ring can become displaced and it will leak.
been there...done that...and you might have a full fresh tank as well so its a wet job if it leaks.:Sad:
Dereckerick
Dereckerick
236
136
Merseyside
You can probably tell by now im not the best DIY bloke, but its nice learning more about the MH, and getting some practical tips.
I wont tell of my sink unblocking last night, its just asking for a ribbing!! Lets just say a couple towels had to be thrown out:Blush:
You even remembered my name!
