Plastic push in fittings (1 Viewer)
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
Where online could I buy 2 push in fittings to screw onto the ends of the fiamma tank acumalator , the threaded ends on the end of it are the same as on my shurflo pump
Here are some pics of what I am after.
Also here is the tank that they are to screw onto
Amazon product ASIN B0013DVW3C
Sep 10, 2012
2,133
3,714
worcester
Sunliving van
Type 'push fit 10mm water' into eBay search - replace 10mm with the size u need
Jul 29, 2007
6,551
39,658
Ipswich
RV and PVC
30 years
BSP, possibly 3/8 or 1/2 female to 10mm
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
I suspect that this is the one:
Link Removed
ok im sure its 12 mm and not 10 mm as its written on the hose as 12mm
and on the female fitting is stamped "BSPP" and when i measure the inside diameter of the threaded end you would just fit a 3/4 piece of pipe into it,, so does that mean its 3/4 BSP ???
if so then this one looks like the right job ?? even if its expensive for all it is
Link Removed
jtp890
591
393
wakefield
Dethleffs 7014
13 years on n off
If the e bay one is a jhon guest fitting, nip down to wickes and see what they have, they stock john guest plastic fittings.
cronkle
111
47
shropshire
c class
since1995
The proportions look the same as in your original photos and the description, '12mm John Guest Pushfit Pneumatic Fittings For Water Air Vacuum Filter Pump Pipe' suggests you have hit the nail on the head. (y)
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
ok so i just took the rubber washer out of the fitting i have and measured its diameter and it was 20mm as close as i could measure , so then i found this bsp chart :
Link Removed
so i would take it that due to the above i need 1/2 BSP female fixing and then going by my current hose having 12mm written on it , i need a 12mm fixing , so as per the one @cronkle posted
