Peggypegs (2 Viewers)
Mousy
3,485
20,319
Sa15 2DG
Hymer S840 Merc auto
Mr Mousy is an reluctant erector...of our awning. He's read too many horror stories on here.
I saw these at Malvern and wondered if they would help him feel more secure about getting it up and leaving it out?
http://www.peggypeg.co.uk/peggypeg_products.php
Anyone used them? Anyone got some they don't use for sale? At ÂŁ50 for the pack, I'm nervous of buying something else that stays in the garage along with the windblockers because "it's too windy for that awning to be up".
Chris
21,056
279,014
10 years
We have got the fix and go things - very good if you just want the wind out and a bit of protection against wind.
We also have just bought ( well my wife has just bought) some screw down pegs that you drill into the ground to peg the awning down. They are excellent if you are pitching on grass and easy to get in and out with a rechargeable drill .
Edit - they also avoid you hitting your thumb with a lump hammer, which I seem to specialise in.
Mousy
Mousy
3,485
20,319
Sa15 2DG
I was just very envious of the few motorhomes that had their awnings out all weekend at Malvern. We used Cliff and Ger's pop up quest gazebo so actually didn't need our awning but with 2 weeks in France coming up I'd really like to use it more.
It's frustrating that when you actually want to use the windblockers its deemed too windy to be safe to have the awning out. :eek:
18,035
48,139
If your awning is like mine, a Fiamma, then the top of the legs go into a bit of plastic. It's a fairly substantial bit of plastic but plastic nevertheless and this in turn is retained in the awning rail by friction from a single 6 mm bolt - which can come loose in my experience. I just put a peg through the plate at the bottom of the leg but the main safety comes from an awning tie-down kit which I got from Lilypad Leisure. This slots into the groove in the awning rail and though it doesn't stop the awning flapping in a strong wind it does give a reasonable amount of confidence to a cautious erector like me. :)
Chris
21,056
279,014
10 years
Have you got storm straps to hold the wind out down?
It would take quite a gust to damage the awning with those fitted.
We have left ours up several times for two weeks at a time in Spain and it didn't move.
Ours is an Omnistor but I did see a few Fiamma's flapping around.:whistle:
Feb 24, 2013
13,089
101,496
Bolsover, Derbyshire
Hymer S800
not long enough
be cautious of tie down straps as well, we use them, Bev took MH away to a WI do a few weeks ago and wanted awning out, I stressed (possibly over stressed) the importance of the tie down straps, which are ratchets in our case, we now have a bent front rail on the awning that will not wind away properly o_O
But at least it didn't get damaged by the wind (y)
I really cant see those square plates and pegs holding a wind out in a decent French gust of wind, sorry Dawn, Martin needs to continue with his cautious approach, and you need to continue to take someone braver to travel with you so you can use theirs :LOL:
Mousy
Mousy
3,485
20,319
Sa15 2DG
Hi, yes we've got storm straps and it's the ominstore that you can lock the arms of, so surely it should be safe.
Spent 2 weeks next to an Italian at lake annecy last year, his was up and strapped down the entire time, ours was in and out more times than I can remember!
Feb 24, 2013
13,089
101,496
Hymer S800
not long enough
I would be happy to leave mine out with our straps securing it, hoping for a decent gust to straighten the front bar o_O
seriously tell Martin not to be quite so worried, caution rather than outright fear will do (y)
Mousy
Mousy
3,485
20,319
Sa15 2DG
QUOTE]
Oh no sorry about your rail, but thanks, no chance it will be used once Martin reads that!
Mousy
Mousy
3,485
20,319
Sa15 2DG
We used them when we had the Hymer. Might still have them somewhere.
Those are the ones @Jim if you come across them sometime, happy to take them off your hands guvnor.
Jim
Ringleader
Jul 19, 2007
36,446
131,020
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Aren't European awning legs delicate. Rather than a wafer thin bit of aluminum foil; American Awning legs are girders, and you can use a truck ratchet on them without them moving or bending. Just another reason why American motorhomes are better. :)
Janine
14,354
43,181
A little bit left of Middle England
2006 A/S Nuevo
since 1988
My legs are my weakest point (n)
It's a Fiamma wind-out. The joint in the middle of the leg (the bit that slides in and out) is secured with a small screw and the top is pop-rivetted. If a leg fails, the storm straps then become useless.
Feb 24, 2013
13,089
101,496
Hymer S800
not long enough
If we could all afford the fuel I reckon we would all be driving them
maybe not though, although they are improving they are still dead ugly, ;) I know its all in the eyes of the beholder etc etc
yet another of the MHing compromises, built to do the job or to look pretty o_O
I am coming round to your way of looking at it (y)
edit - technically the legs are pretty good on mine, it is the front bar which is made of foil :)
Jim
Ringleader
Jul 19, 2007
36,446
131,020
Sutton on Sea, UK
Adria Panel Van.
Since 1988
If you have a regular awning. The front legs on yours will be as strong as the pathetic bit of plastic friction grip which holds the awning leg at the required length. Tighten it too much and you shorten the leg and or break the plastic.
As for the eye of the beholder stuff, I have always thought Hymers look great and just don't age. But latterly for me, the new Rapido A classes look better, as do the Dethleffs. The newer shaped Hymers leave me unmoved. I remember when I thought the new Autotrails with the new shaped overcabs and the incorporated rear wheel covers looked awesome, but they have dated really quickly. However I have loved the look of classic C class yank since I was a kid.
movan
21,492
120,753
Moving around
Burstner
since07
My leg joints are wonky and my awning also tore. Winding it in takes 5 mins so I do that .. Thought you bought new pop up like Popeye, Dawn?
Mousy
Mousy
3,485
20,319
Sa15 2DG
No it's Cliff and Ger's, we just squat in it. :rofl:
Mar 29, 2011
961
639
Rugby UK
C Class RS
there really is only one awning that will take high winds and its a GH ( The awning company ), its more substantual and made to order, the downside is that they are expensive, the worst weather I have had mine up in including the safari room was with gusts up to 70mph, this is the one on my last motorhome a Hobby Sphinx which is at the moment on sale at Campbells nr Preston
