Pappajohn-----Tow-bar (1 Viewer)
Sam and Viv
117
74
fife
hi-top
of-on with caravans-40yrs
Pappajohn
when you fixed your tow-bar to the m/home did you use spring washers or ordinary washers and bolts.
Thanks Sammy:thumb:
Aug 30, 2012
4,270
11,305
Home of the war horse
burstnar T640
Pappajohn
Thanks Sammy:thumb:
Where there is chance of movement I always use flat washers then spring then nut
Or flat washers and locking nuts
On such as a towbar a must for me
And use heavy duty washers not the cheap crap
peter
buckby
213
147
nottinghamshire
coachbuilt
Tow bar
Deffo spring washer when I fitted mine and nylock nuts just to be sure
43,331
49,467
sorry for late reply Sammy.
i used flat washers on the alko chassis side and flat washers plus nyloc nuts on the plate side.
i used M12 (17mm spanner size) nuts and bolts all round.
no torque data so just tightened them 'grunt' tight then check again after a decent towing run
using nylocs negates the need for spring washers
N&K
220
42
Berkshire
Swift Sundance 630L
when swap the towball for the motorbike rack, I replace these between the ball and mount each time:
Internal Serrated Lock Washers, Stainless Steel M16
[ame="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=360479562013&var=630052339785"]http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=360479562013&var=630052339785[/ame]
Sam and Viv
Sam and Viv
117
74
fife
hi-top
Pappajohn---------Tow-bar
Thanks to every one + Pappajohn great response :thumb: as usual, will get tow-bar painted tomorrow and fitted next day weather permitting.
thanks Sammy
