Hi All
Hope someone can help me, I have worked out all of the other
buttons on this control panel accept the one next the the 12 volt light.
It has EIN above it and AUS below
Many thanks Ian
Thanks all and thanks for the welcome, Mike
Thanks for the tip on input and output, must really brush up on my German!
I took it to Germany last year too. Should have askedoh:
Have turned the switch on and off and red light stays on. Am just going to check it with my meter.
Will report back
Thanks again
Ian
could be to switch the charge between hab and cab batteries ein being internal ( hab ) and aus being external ( cab )
caravans had this feature so you would switch it to car when traveling to charge everything from the car engine. then when on site you switched it the other way to use the caravans battery for lights etc..
