Panel meter (1 Viewer)
jordano
170
8
blackpool
Triango CI Cipro55
3 years
Wonder if anyone can help me to wire this up. Bought from China on eBay but a bit confused with instructions see pictures. It says connect the meter in series with load is charger the picture shows two figures for charging and discharging . I have a battery to battery charger from vehicle to Leasure batts thank John.
grasscutter
2,469
8,632
East Wittering. West Sussex.
Hymer Exsis i588
Started in 1980
Can't help but you might want to edit your photos. You have included a copy of an invoice to Blackpool Tower that includes your name, phone number and email.(y)
43,329
49,444
first pic explains it clearly except the charging pic has the battery and charger on the wrong terminals.
the battery needs to be on the output terminals and the charger on the input terminals.
EITHER charge current/volts OR discharge current/volts,,,but not possible to show both alternately without some kind of cross switching in the wiring..
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
Must be getting old putting wrong pics up thanks for replies
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
I don't think it's trying to show both alternately. I agree the diagrams could be clearer, but I imagine what the meter is designed to show is net current flow either in or out.
Bit of a guessing game without seeing the full instructions. It looks an unconventional way to wire an ammeter though - you would expect it to be measuring voltage drop across a remote shunt rather than having the whole current passing through the meter itself.
Lenny HB
53,430
149,981
On the coast in West Sussex
Hymer B678 DL
I have the same unit.
You need to fit the shunt in-line with the battery negative, and connect 3 wires to the shunt, 2 to one side and 3rd one to the other side, full instructions should make it clear, if it is the same model as mine you can power it from the same source that it is monitoring so just need to feed a 12v supply to V+ and link to V in.
@pappajohn, this unit shows charge & discharge if wired correctly, discharge the "A" Led is lit, charging the "Charging" Led is lit. Can also be set to watts instead of volts, and you can program the A/H capacity of your battery and if will display % of charge. Not bad for 20 quid, only downside is the sample rate is set at 5 per second, so the display is constantly flickering
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
Thanks for replies mine has a shunt built in i have drawn a crude diagram of the way I think it wires up and on test does seem to work should I put fuses on the live feeds?.
