Paloma leak (1 Viewer)
merlster
7
kent
talbot express
about 6 years
Hi all.I have a paloma ph-5-3f (mk v) water heater in my Talbot Express Camelot.Used the van proper last week.The heater then developed a leak:helptitanic:.I have enclosed a pair of photos.The leak appears to be comming from the back of the temp regulator dial.I have removed the dial assembly and checked for cracks,but can see nothing.Has anyone else had this problem and if so help me with this problem.Many thanks Les.
Broken Link Removed
Broken Link Removed
JJ
Mágica
May 1, 2008
19,259
48,046
Burstner Privilege T
over 50 years
Great heaters if properly fitted... I repaired a couple of leaks in mine in the past... I replaced it in the end... I wish I hadn't...
Now... a question... Are you certain where the leak is coming from? Mine had a frost damaged leak and it looked as though it was coming from a fitting but in the end it turned out to be a split in the pipe above the fitting... an easy to repair with solder fault...
Sorry if this is Grandmas and Egg sucking...
JJ :Cool:
ourcampersbeentrashed
7,574
4,348
East London
well over 5 years
There is someone on ebay who repairs these and sells 2nd hand ones.
May be worth a look to see if they are near you
