Oyster Vision stick or fix
Discussion in 'TV & Satellite' started by xjrchris, Feb 23, 2013.
  1. xjrchris
    xjrchris Funster
    Apr 17, 2012
    165
    85
    bath
    i have bought a s/h oyster vision sat dish and was wondering is it best to stick or fix with bolts the mounting plate? i dont like the thought of drilling the roof more than i need to ,but will it be safe if i stick it ? has anyone fitted one??? thanks chris
  2. SuperMike
    SuperMike Funster
    Apr 28, 2010
    948
    1,060
    St Albans
    Ours is bonded to the roof with Silkafix. Been there two years now. Perfect, even when I dismantled it all to convert it to a dual LNB the plate stayed stuck firm to the roof. :thumb:
  3. Dai
    Dai Read Only Funster
    May 14, 2008
    47
    24
    West Wales
    Likewise, stuck to the roof with Sikaflex since 2007. Checked every time I wash the roof.
    No problems. Don't forget to score the roof after cleaning thoroughly prior to fitting anything. I scored underneath the Solar brackets using emery paper.
    Dai
  4. Pikey Pete
    Pikey Pete Read Only Funster
    May 25, 2008
    1,532
    1,141
    o
    All the ones I've had, have been stuck to the roof using the plate supplied with the system.
    I've not heard of one ever coming adrift.
    Pete:Cool:
  5. 1Oll
    1Oll Read Only Funster
    Jan 12, 2010
    175
    86
    Cheshire
    As it was the first job I had ever tackled like this, I chose belt and braces. Sikaflex equivalent and stainless steel self tapers. Two years no problems. To remove a plate use hefty fishing line wrapped around a couple of handles and use in a sawing motion like a cheese wire.
    I bought my Oyster secondhand and its been really great. If you like TV just dip into your savings and buy one. Press the button and its on. I've got mine rigged to an Aldi Digibox with a really cheap TV bought from probably the best dealers, Richer Sounds, with a 5 year warranty. The TV is so light I thought it was a display model. I've tuned my Freesat and used DISeqC, I can then chose a programme on the freesat box from a different satellite and the Oyster dish moves automatically to the correct preprogrammed satellite. Used it to watch the F1GP when it's not on BBC.
    Brian.
  6. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,517
    Tyne & Wear, sometimes..
    Stick it properly with Sikaflex or equivalent..
    It will not go anywhere...:thumb::thumb:
