Over voltage from solar panels
Discussion in 'Solar Power' started by Stealaway, Feb 10, 2016.
  1. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,253
    1,326
    Dronfield - Derbyshire
    I have this kit wired to my starter battery and my two domestics.
    It's working a treat and charging the battery's easily.
    The problem is that the voltage to the start battery is occasionally going over voltage - to 16.2 volts.
    The supplies sez the voltage can increase because of a low ambient temperature, I'm not convinced.
    Any ideas peeps?
    http://www.ebay.co.uk/itm/20A-12V-2...392978?hash=item2808dcffd2:g:4VIAAOSwEetWBOmN
  2. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,884
    7,987
    Plymouth
    • Like it Like it x 1
  3. andy63
    andy63 Funster
    Jan 19, 2014
    2,407
    9,441
    south shields
    What's the voltage reading on the habitation batteries... I'm reading it that both battery banks are connected to the the charge controler... and would expect to see the same voltage on both battery banks.
    And have you confirmed that voltage with a meter...
  4. andy63
    andy63 Funster
    Jan 19, 2014
    2,407
    9,441
    south shields
    The first link is to a single outlet pwm controler with remote panel and the 2nd to a dual output controler ... which is it...???
    • Useful Useful x 1
  5. jollyrodger
    Oct 1, 2012
    3,884
    7,987
    Plymouth
    If it is charging two banks . as stated in op ,it should be the link for the duo .
    Also you can decide the ratio of charge (50/50% etc the default is 80% start batt /20% aux batt) according to my paperwork .
    Unless others know different :)
  6. andy63
    andy63 Funster
    Jan 19, 2014
    2,407
    9,441
    south shields
    Yes that makes sense.. I'm not sure how a dual output works and whether it regulates the load voltages separately
    My habitation batteries are connected to a single outlet mppt controler but then to the vehicle battery through a voltage sensing relay and I see both voltages the same on each battery bank... hence my question above...
    16.2v does seem excessive for the load voltage...
    • Like it Like it x 2
  7. jollyrodger
    Oct 1, 2012
    3,884
    7,987
    Plymouth
    I have the remote also as part if the system ,which sometimes give figures that I don't believe ,so have a digital readout plug in which shows a steady 14.2v (200w solar panel) in hot Clime's it usually gets around 14.8v I'm happy with that :)
  8. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,253
    1,326
    I am getting 14.2 ish to the leisure battery's continually. I have it set to to 50/50 at the moment and the leisure are fully charged now - as is the start - I think!
    Just not happy with it going up to 16.1V at times.
    I could try swapping the connections to the start with the domestics and see what happens.
  9. jollyrodger
    Oct 1, 2012
    3,884
    7,987
    Plymouth
    You shouldn't need to swap any connections ,your number 1 batt (starter) is by default being changed @ 80% you can alter that from the controller .if you haven't got a user guide download a PDF from the link I gave earlier .
  10. denisejoe
    denisejoe Funster Life Member
    Aug 6, 2014
    1,483
    1,026
    Isle of Sheppy
    I would have thought that the leisure battery would have been the no 1 for charging
    joe
  11. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,253
    1,326
    That is the way I have it set up but because you can alter the bias from 20/80% to 80/20% it shouldn't make any difference.
    Why would you think that number one battery connections should go to the starter battery
    I have the same instructions that came with the controller and the amp meter. Neither are much good when you have a fault.
  12. jollyrodger
    Oct 1, 2012
    3,884
    7,987
    Plymouth
    I have the same instructions that came with the controller and the amp meter. Neither are much good when you have a fault.[/QUOTE]
    Should have put for example :LOL:
  13. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,378
    3,153
    Kendal, Cumbria
    Before going further check battery voltages with a digital meter (as suggested above). And, a separate question, what is the charge current reading when you see 16.2v?
  14. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,253
    1,326
    As an ex electrician I have been using a multi meter nearly all my life. This one is a Fluke 77 series
    The Electrobloc panel shows the start battery voltage off the scale (+15V) when I measure the starter battery with my meter its is at 16.2 V
    The voltage on the panel for the domestics shows 14.4V and the same with the meter.
    I haven't measured the current reading but the amp meter shows +4/6A from 250W of solar panels (bright sunshine but in Derbyshire)
    The controller settings also has a 'frequency setting' but doesn't explain what this refers to.
    This is the controller-----http://www.ebay.co.uk/itm/391336201309?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
  15. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,532
    3,757
    Lost in La Mancha, Spain
    Have you tried swapping over the output from A to B and see what reading you get then? remember to cover solar panel before removing wires
    • Useful Useful x 1
  16. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,253
    1,326
    That's going to be my next step
  17. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,378
    3,153
    Kendal, Cumbria
    I don't believe you should ever see over 14.5v-ish. IMO the controller is faulty.
  18. walburga
    walburga Funster
    Aug 20, 2007
    309
    107
    Leyland
    The manual for that solar reg states that the battery will show a boost charge of up to 14.8 volts, depending on what type of battery the user has programmed in.
  19. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,532
    3,757
    @Stealaway - Well how it it go?
  20. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,253
    1,326
    Not today - been busy most of the day with the computer. Replacing the new video card drivers led to the mega download of the new Windows 10 upgrade and much more. It took most of the day.
    I'll let you know tommorow.
