Outline LED Marker Lights, the red/white ones up top? (1 Viewer)
Oct 25, 2022
175
180
Infinity and beyond
Burstner Lyseo I 726
A very long time
Has anyone ever changed one of these on a Burstner Lyseo. I’ve cracked one, got a replacement from my dealer and tried to swap it earlier. Unfortunately there is absolutely no slack in the twin cables in the van to the old light unit. I’m sure there’s plenty but I’m guessing Burstner have stuck or fixed the cables to the inside of the upper side panel. There was loads of what looks like black chewing gum around the mounting holes and screws. I pulled this off to clear the hole the cable passed through but the cables didn’t budge more than about 25mm. I didn’t fancy giving it a good tug for fear of either breaking the wires or pulling the spade connections apart and losing the cables inside. There’s no access points in any of the rear upper bedroom cupboards, this has me beaten. Any guidance, tips etc would be really appreciated.
Thanks in advance
Blue Moon
Feb 22, 2011
10,003
20,695
Newcastle under Lyme
Hymer B544 A Class
Since 2015
The "black chewing gum" will be non setting mastic and needs to be replaced if you cleaned it off.
Don't pull on the wires, much better to extend them if there is insufficient to work with.
Blue Moon
Oct 25, 2022
175
180
Infinity and beyond
A very long time
What non-setting mastic would you recommend?
I’ve about 25mm of slack, if I cut the old wires where they come out of the old light unit. What would be recommended as a cable connection that’s easy to work with on a tight cable run and a 10/12mm hole in the body?
3,860
7,662
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
I find Wago connectors are very useful. Available as pass through in multiple configurations.
Lenny HB
54,218
153,228
On the coast in West Sussex
Hymer B678 DL
I think Wago's would be too bit.
Solder but joints might be the answer.
1,596
2,919
UK
Burstner Travel Van
Few years now
Got a set of them, absolute rubbish. Better to solder the proper way.
