On the level
Discussion in 'Motorhome Chat' started by Benwick Rambler, Jun 13, 2009.
  1. Benwick Rambler
    Benwick Rambler Read Only Funster
    Oct 21, 2008
    42
    Cambridgeshire
    In an earlier thread on the subject of Smart Car trailers, I posted a picture of my car on its trailer which prompted a comment by Geo on the potential hazards of this “tail-down” configuration.
    I too had some concerns about this and took the opportunity to visit PWS last week as I wasn’t too far away staying on the new Caravan Club Centenary Site at Bransgore. The people at PWS kindly fitted my new drop plate (supplied by me) at no cost. As you will see from the before and after pics, the trailer with car onboard is now level and the tail end ground clearance has increased by about 2 inches. The only draw back is that ground clearance at the drop plate is similarly reduced and with a very long overhang on my motorhome, I’ll have to be careful not to “ground it”.
    Brian
  2. hilldweller
    Dec 5, 2008
    26,880
    25,737
    Macclesfield
    OK, you are ready to get on the ferry..... KERRRRUNCH.
    Load of people behind. Can't go forwards.
    What do you do ?
    Better to work it out now.
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,689
    5,841
    Mansfield,Notts
    Hi Brian
    Glad you have got it sorted, the issue of getting stuck on a ferry fades into insignificance compared to the trouble you may have got into with the rig as it was:Doh:
    Much better to offer a solution than throw the spanner in
    So your stuck on a Ferry
    Bin there got the T shirt:RollEyes:
    Rule 1
    Don't panic, no one is going anywhere till your sorted:thumb:
    Rule 2 Do not Damage your motor home to expedite matters, take all the time you need
    Rule 3 Its more their problem than yours, let them sort it, you wont be the first or last
    Our American big rigs collide with the ramps almost on demand, we have a solution
    fitted to the tow bar is a steel or nylon roller. they sound horrific when they bottom out ,but cause no damage
    If your at all worried by grounding fit one:thumb:
    Geo
  4. gazznsam
    gazznsam Read Only Funster
    May 15, 2009
    273
    Eastwood, Notts
    the solution for grounding on ferry ramps is simple, a pair of wooden blocks, if/when the tow bar drop plate grounds, stop, place the blocks under the rear wheels, then drive on, the wheels go over the blocks and raise the vehicle up,
    by the time your at the end of the blocks, the ramp angle has changed, and you have clearance again.
    i know that on norfolk lines ferrys when booking you can tell them you have low ground clearance, and they will put you on the middle deck with the trucks, this one is an almost level entrance ramp,
  5. Benwick Rambler
    Oct 21, 2008
    42
    Cambridgeshire
    Thanks for your thoughts, but I've no plans to go abroad so the ferry problem won't arise.
    Brian
