Omnistore Awning (1 Viewer)
olympus
8
High Halstow. Kent
Coach built
New to this
Hi there,
I'm new here so treat me gently:Smile:
The awning mechanism on my Autotrail 650 Apache has failed & will not fully retract it,
The repair job itself looks fairly straightforward, but i have a couple of question if someone could advise.
Does the complete awning assembly have to be removed to carry out the repair/replacement
If it does where are the mounting through bolts located that secure it to the van side??
Many thanks for your assistance
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
Hi there,
I cant answer your removal point to repair it, but the back end of the bolts will be in your top lockers usually 3/4 along the length of the awning, I have never had to repair one (touch wood) but I would imagine an easy removal if required. Pete
Ps welcome to the site. :thumb::thumb::welcomefunster::welcomefunster:
Apr 25, 2012
794
826
Near Truro, Cornwall
Omnistor awning
Hi, this may not be much help but here goes. We have a 4.5m Omnistor awning on our van and on one occasion last summer, I could not get the thing to relocate flush with the mounting no matter how many times I rewound it. It wA the last couple of inches. The Problem was that I hadn't clipped the legs back into their channels properly. Once corrected, it worked fine.
If yours is a more serious problem, I'm sorry I can't help, but I'd be amazed if there isn't an old thread on this, so worth searching this site.
GJH
29,450
38,827
None, now sold
2006 to 2022
Hi, this may not be much help but here goes. We have a 4.5m Omnistor awning on our van and on one occasion last summer, I could not get the thing to relocate flush with the mounting no matter how many times I rewound it. It wA the last couple of inches. [HI]The Problem was that I hadn't clipped the legs back into their channels properly. Once corrected, it worked fine.[/HI]
Beat me to it as we had the same problem earlier this year. It turned out that I had the feet the wrong way round so the legs wouldn't clip in properly.
olympus
olympus
8
High Halstow. Kent
Coach built
New to this
I think this is how the mechanism has got broken...the legs not correctly stowed & the awning wound in, but rather than stopping when the winding got stiff...it was just continued to be wound in & that that
I have looked today for through bolts but cannot see any, so i have to assume these are behind cabinets or covers within them, which i cant yet find
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Since 2010 Caravan since 1995
On a Prostor which is the new company started by the old Omnistor owners after it was sold.
You are able to alter the stor by adjusting the arms where they join the front .
It will be trial and error but move the end of one arm a small amount further along then wind it in.
If its worse than before go the other way till you get it right.
Hope this makes sense.
Mel
peter marshall
2,466
1,704
Low Line
9 Years
They are usually in the top cupboards some have a plastic cover square or oblong. Pete
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
If you have no joy, give Glenn or Ian a call when we reopen after Boxing Day, now you need to Link Removed << here to get all the benefits of being a Funster
Peter
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
If the awning is fitted into the correct alloy brackets (you can see them from the underside - one near each end & one or two others in between depending on awning length) you can remove the awning by simply removing the self-tapping screws in the underside of one or more of said brackets. Once the self-tappers are out the complete awning simply unhooks from the brackets without touching the fasteners that hold the brackets to the van.
TheBig1
17,630
43,323
replacing the gearbox can usually be done with the awning still attached to the van. unscrew and or drill out rivets on the end cap with the winder in. release the screws holding the gearbox and slide out. reassembly is a reverse procedure
it may not be damaged too bad though, unless you forced it. simply unwind fully and check for twigs, fir cones or debris and then refold and clip the legs and try again
John Rose of rose awnings specialises in omnistor and will happily talk you through the repair or adjustment and may have the parts in stock
http://www.omnistorawnings.co.uk/action/contactus/
happypre65
137
53
Hi, We use ours most weekends whatever the weather,but we have to have one end lower than the other to let the rain run away,so hence the awning tends to go in except the last few inches,if you look at the clip that it is supposed to go in i am sure if you get your awning handle and just pull down the end of the awning quite hard, you will then be able to get it to retract,been doing this for years, and also as said the legs are important,the other thing to look for is if you have any bits of trees only small bits because they collect at the front of the awning over time,again it will not retract,just need to run your hand along before winding in,regards H.::bigsmile:
