omnistep refuses to retract fully (2 Viewers)
pegasus
61
Bristol
since Nov 2009
Hi,
I have an electric omnistep 12v 550 and few weeks ago started playing up.
It always extracts ok but fails to retract fully. When it is half way in it apears that has a bit of play (feels somewhat loose on the joints).
I took it to a caravan repair shop and they told me that it is not the switch, it might be the motor or the relay. I want to fix the paly on the joints as well. Can these steps be serviced anywhere? or should I be looking for a new one, In which case I will go with the manual I think.
Kind regards
Jim
Ringleader
Jul 19, 2007
36,454
131,072
Sutton on Sea, UK
Adria Panel Van.
Since 1988
It will probably be the step limit switch that needs cleaning/replacing look for it on the left of the step, it gets gunged up with road dirt:thumb:
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Hi pegasus
Don't know what you have tried, but these steps are in a very dirty environment and will often lock up with grit etc. It might be worth giving a spray with WD40 or something like on the bearings, I normally spray with a silicone lubricant after every trip, or if bad weather experienced while away, and find this normally takes care of any problems.
Hope you get somewhere with your problems.
Dave .:thumb::thumb:
haganap
12,765
26,477
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Try an air line to blow all the crap and gunge away. Mine done this a few times especially after winter. I took it apart blew it all out and bingo, job done.:thumb:
rob kinnear
175
31
Swansea
Hi Top
1 year 10 years tugger
I had a similar problem and it was the switch that was playing up under £7 from vanplus crosshands . I have also had a relay stop working I took the old one to my local motor factors and they found a replacement for £3.50
Best of luck
Rob
pegasus
pegasus
61
Bristol
since Nov 2009
Thank you all for your advice.
I have disconnected the arm from the motor and the step moves freely, but with some play on the joints. Also motor turns fully both ways without load. Is there any way to tighten the step? i.e. minimise play on joints?
