Old glue removal - tips please...
Discussion in 'Motorhome Chat' started by Trikeman, Apr 30, 2013.
  1. Trikeman
    Trikeman Read Only Funster
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Hi All,
    on old carpet removal, the inner wheel arches (the ones inside the cab area) have the original rubbery liners which have thick, hard glue residue on them - I mean thick lines of it. Has anyone got any tips for removal of this?
    I would like to remove as much as possible to enable a flat surface to mount the new carpet on.
    I don't think it's the spray type glue, more like thick lines of a contact adhesive.
    :Sad:
    As always, any tips or recommendations gratefully received.
    Regards,
    Trikeman. :Wink:
  2. G4OGE
    G4OGE Read Only Funster
    Apr 11, 2013
    202
    161
    Northwich,Cheshire
    Might be worth a go
    I have seen the sealant along roof joints removed at caravan repairers done with a piece of wire in a drill on slow it collected it on the wire it may work if it's similar.:thumb:
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    I fear a mechanical attack is going to be most successful
    adhesive removal wheels are available for drill use
    or as the surface is to be re carpeted paint damage should not be a problem
    Id go for a Stanley Window Scraper. it hasnt got to be super smooth has it
  4. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,531
    1,421
    West Midlands
    • Like Like x 1
  5. Daveo2006
    Daveo2006 Read Only Funster
    Jan 25, 2013
    1,168
    987
    kent
    Try the scraper along side a hot air gun if you can get your hands on one.A hair dryer may soften it up too.
  6. petensal
    petensal Funster
    Feb 22, 2012
    160
    148
    Lincoln
    Try paint thinners, turps, maybe wd40.
    Try on a small area out of sight if pos, use with a small paint brush or piece of cloth, if it starts to soften old glue then try to peel off.
    Pete
  7. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    3,994
    6,488
    Roobarb land
    Don't laugh
    Nail polish remover
    • Like Like x 1
  8. Trikeman
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Thanks all,
    away from Friday but will try ideas when I return and will report back.
    Again, thanks for the recommendations.
    Regards,
    Trikeman. :Wink:
