Can I know what is the oil pressure level on the gauge for Peugeot Boxer 2.2 2016 , it shows 0.6 Bar , and what is the problem and how to solve?
Osama
0.6bar is 9psi which is low.
Is this at tickover? If so not too bad.
If it's at higher engine revs it does indicate a problem.
Has the vehicle done a high mileage? Could explain overall wear.
Has the engine been serviced? Has it got the correct oil in and the correct oil level?
Could be oil pump wear or overall wear on crank and main bearings etc. A symptom of high wear can be hard knocking noises particularly when pulling hard.
