Oil level
Discussion in 'Peugeot' started by stevec, Sep 21, 2014.
  1. stevec
    stevec Funster
    Sep 24, 2013
    614
    207
    Norwich
    2006 2.2hdi Boxer. Topped up my oil and now instrument pod says level high. About 3 to 4 mm above top mark on dipstick. Should I attempt to drain some off? I'm in the middle of France at the mo.
  2. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,805
    39,332
    Not the brightest person to answer... but could you not get a few foot of very thin plastic type hose and stick it down the dip stick hole and suck a bit out at a time...
    Using clear you will be able to see the oil coming up... and stop before you get a gob full..
    Or possibly drain some off from the nut on the bottom... but make sure the oil is cold.... otherwise you will burn your hand putting the plug back in..
    • Like Like x 1
  3. icantremember
    icantremember Funster
    Sep 2, 2010
    5,342
    7,467
    Nr Watton in Norfolk
    I used to have a pump for removing oil through a dip-stick tube in the way Old Mo suggests but does it without drinking the stuff.
    This pump was for use on a boat so it may be worth calling into a boatyard round your way.
  4. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,233
    16,836
    Liverpool.
    Smart cars do not have a sump plug, old oil is sucked up through the dipstick tube. Find a Mercedes or Smart dealer and he will sort it.
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,947
    17,612
    YO11 2BD
    Personally, 3mm to 4mm..... i wouldnt bother if the light can be ignored.
    It probably equates to 1/4 ltr or so.
  6. stevec
    stevec Funster
    Sep 24, 2013
    614
    207
    Norwich
    The level was about 2\3rds between low and full on the dipstick and I put in about 800ml.
  7. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,089
    2,930
    Kendal, Cumbria
    Absolutely. It will do no harm whatsoever.
