oil leak on Mercedes hymer
Discussion in 'Hymer' started by marcus153, Aug 2, 2015.
  1. marcus153
    marcus153
    Jan 28, 2014
    89
    55
    Oxford
    hi all
    I have discovered an oil leak on my 2000 hymer S630. This seems new as not noticed any oil before on floor at storage. Maybe a stone chip on front cooler? the oil seems very clean so could be a clue?
    I wondered if anyone knew of a Mercedes commercial independent around Oxfordshire area?
    thanks
    Marcus
  2. tonytange
    tonytange Funster
    May 19, 2013
    22
    17
    Southampton
    Hi Marcus when you say oil leak and it's clean the two things don't add up engine oil unless changed very regularly will always be dirty to some extent clean oil could be gearbox or power steering oil it would help if you could pin point underneath were the leak appears I don't suppose anyone has top up your oil recently as it sometimes takes a while to seep down. Before you drive any further please check engine oil, power steering oil and brake fluid which is another possible
    Tony
    • Like it Like it x 1
  3. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,925
    1,944
    Warwickshire
  4. marcus153
    marcus153
    Jan 28, 2014
    89
    55
    Oxford
    Hi @tonytange The oil is very clean so could be from somewhere else? If looking at the van it is on the left hand side dripping from the tow loop at the front. But obviously could be seeping from anywhere? How do you know if you are low on gearbox or power steering oil?
    Thanks @JeanLuc will give Banbury a try as motorhome is stored close by.
