oil fire heaters (1 Viewer)
Jul 8, 2008
1,137
1,467
Weymouth, Dorset, UK
c build
6 yr
THIS IS NOT MINE hope it helps
WARNING WARNING WARNING WARNING
To anyone who may have purchased a Challenge 1KW Mini Oil Filled Radiator (most likely from Argos) you may want to switch it off NOW! Thank goodness for smoke detectors and my motorhome being on the drive. I bought one of these a month ago, but noticed a little oil had spilled out of it, so took it back today and exchanged it for another. Big mistake. Only three hours after switching it on, hot oil has run out burning a large hole through the carpet and damaging the wooden flooring underneath. The van wa
43,329
49,444
Another scare story.......
The oil will never get hot enough to ignite anything.
Its no different to oil in a chip pan.
The worst it will do is ruin the carpet.
No matter where its bought or what make it is it's always worth standing it on a tray just incase it does leak.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
It's a lot different to oil in a chip pan - because it's no-where near as hot as oil in a chip pan :). The oil inside any oil-filled heater is no hotter than the outer metalwork so if your hand doesn't burst into flames when you touch it the oil won't either.
