oil filter prob ARGHHHHHHHHHHH (1 Viewer)
Mar 1, 2009
75
11
Lincolnshire, UK
Motorhome
All booked for peterborough next week, only van is immobilised!!! :cry:
My boyfriend tried to take off the oil filter to replace it with a new one and put a screw driver through it and now it wont come off :Doh:
I have homestart with my car insurance im gonna give them a call 2moz to see if i can wangle them dealing with it somehow, failing that ill have to wait for my brother to come up from weymouth in ten days, but that will be too late for the show:Sad:
Has anyone else ever experienced this problem? xjx
shifter
67
wee island across pond NI
coachbuild
3 years
hi junan
i have allways used a thin leather belt when it wont come of withe hands.
good luck
IAN
Boo
633
4
Cornwall
A cls
9 years
Does you have an oil filter remover? if not you buy them for a couple of quid from your local car shop :thumb:
Will come out in a jiffy with that tool (looks like a noose)
Boo
American Dream
156
Lincoln
Try Spraying a bit of wd40 on the seal and using an oil filter remover?
The seal is replaced with the filter anyway.
Just a very light smear of oil on the new one should make it easier next time.
They are usually overtightened on replacement....
:cry:
I do mine up by hand and then tighten another 1/4 turn.It normally mentions it on the box.
ginge61
429
n/wales
c class/t25 vw
since noah was a lad lol
if you look at the filter it has a steel rim round the top of it use a screwdriver to tap this round idealy a small drift or chisel is better and it should come of anticlock wise or like the others say an oil filter rench
bevo
218
4
north west
c class
oil filter
hi junan
i always use a screwdriver to take oil filters off.
use a sharpish cross head screwdriver, and pierce the oil filter towards the end (furthest away from the threads) if it won't pierce the filter with hand preasure,
lightly tap the end of the screwdriver with a small hammer till it goes through the metal of the filter, push the screwdriver through the filter and out of the other side of the filter(screwdriver has to be longer than the diameter of the filter).
when the screwdriver has gone right through the filter, turn the filter with the screwdriver.
it's worked everytime for me
may the force be with you :ROFLMAO::ROFLMAO::ROFLMAO:
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
I would also suggest filter removing tool (just a couple of quid) also check the drain plug as it may well not be just a hex type nut. Tool to fit your ratchet again not expensive.Remember anti-clockwise to undo ::bigsmile:
43,329
49,444
if you cant get the correct tool........
home made removal tool.
one short thin leather belt, like on an old fashioned roller skate
one large ring spanner.
place the belt through the 'ring' of the spanner and around the filter,
leave quite a bit of slack and buckle the belt.
turn the ring spanner anti-clockwise using another spanner/screwdriver through the other end.....bit like a sardine tin key.
easier done than said.:winky:
failing that punch two drivers into the BOTTOM of the filter and cross over to form an X.......use the two drivers to lever against each other turning anti clockwise.
only applies if you have the room though.:Doh:
another option, if the filters clean and dry......a pair of marigolds or yellow silicone palmed builders gloves...amazing grip.
J and M on Mfun
Mar 1, 2009
75
11
Lincolnshire, UK
Motorhome
yey ::bigsmile: my boyfriend got the filter off, he used a wrench type thing and brute force and finally after much hurting his hands and cursing it came off, and he did an oil change....engine still sounds like an old tractor though:roflmto:
thanks ever so much for all your replies:thumb: what a brill club this is:Smile: next stop peterborough xjx
MrJinks
580
115
Dorchester, Dorset
C Class RV
6 years
Glad your boyfriend managed to get the filter off ok with nothing worse than losing his temper.
The last time I ever tried to remove a filter with a screwdriver I ended up in casualty with six stitches in my thumb for my troubles :Doh:
The stitches weren't anything as painful as the doctor trying to wipe all the oil out of the wound before he would stitch it. :cry::cry:
43,329
49,444
hope he smeared some oil on the rubber O ring when he put it back on or it'll happen again next time.:winky:
JockandRita
11,462
150,159
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
We'll see you there then. :thumb:
I remember years ago (back in my yoof), when trying to change the oil filter on an old Ford Cortina Mk 1. I was ages trying to get the screwdriver to penetrate the filter, so that I could screw it off. :Angry:
When it eventually came off, I discovered that what I thought was the disposable metal filter....................................turned out to be the filter casing, containing a paper filter. :Doh::Doh::Doh:
I had to scrounge a lift to the local scrappy, and find another. :ROFLMAO::ROFLMAO::ROFLMAO:
Jock.
American Dream
156
Lincoln
Nice one....
Glad you sorted it in the end.
Sometimes they put them in the most awkward of places to get a grip on.:Doh:
