OIL CHANGE (1 Viewer)
Dec 3, 2007
106
57
bristol
fiat autotrail imala 730
since 2005
hi all i have just changed the oil and filter on my 2011 ducato 2.3 130 multi jet engine the manual says 6.5 ltrs i have put 6 ltrs in i have run the engine for a short time after many attempts i am not able to determine the level on the dip stick it just seems to be all up the min/max marks should i take it for a run to maybe settle it down any suggestions ?
Jun 17, 2012
2,932
9,928
North Essex
Autotrail Delaware
>12 but <13
Mine (2011 150 multijet) took just under 6 litres last week with filter change as well.
Spot on the mark on dipstick. Manual says 5.9 litres including filter. Page 263 Fiat handbook, same as yours should be.
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Also, remember when oil changing, you never get it all out, so a measure of the old oil is left behind. :emo:
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
Changed my 07 2.3 Peugeot oil a while ago it's dead on full on the dipstick but the thing on the dash that comes up with your oil level in a number of rings now says high sometimes. Don't know why as it is random doesn't seem to matter wheather it's level on the ground or what.
Nov 3, 2013
3,170
9,384
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
Hi chaser.
Its an old French trick,to keep the Peeps double checking their oil,the SPEEDS... they used to travel at,needed a full sump....LOL.
You cannot beat the old,"Oil Sword LOL"
Tea Bag
jointerjohn
Dec 3, 2007
106
57
bristol
since 2005
i will have to recheck the fiat service book because i'm sure it said 6.5 ltrs would the engine retain 1/2 ltr of old oil ? now ive put in 6 ltrs it looks as if there is too much oil in the engine.
Aug 18, 2014
23,782
133,674
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Yes , even more so if it wasn't red hot when you emptied it. To get a true reading after refilling you need to wait hours. When you refilled it you should wait & check before ever starting the engine.Once started you'll need to wait hours again.
Feb 26, 2012
528
368
coach
Motorhome since 2006 (caravanning 38yrs)
With modern low viscosity oils there is no need to wait so long.
20 mins is more than enough for it to settle sufficiently to see the level.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
It's not critical to be at the top of the dipstick
It's there to show the range of oil level that is satisfactory from min to max
So no need to be hasty !
Just carry a pint in your door pocket for topping up , overfilling is not desirable
Techno
Jul 28, 2010
15,475
20,756
May 2010
Surely not the people who throw good oil away every year regardless of mileage :LOL:
I'd rather change the filter every year and keep the oil
jointerjohn
Dec 3, 2007
106
57
bristol
since 2005
yes i did change the oil filter as well ! and the engine was hot when i drained it! then left to drain with oil filter removed, for a couple of hours, the dip stick has smears of oil all up the dipstick even hours after refilling making it difficult to read or get a level reading from it.
Aug 18, 2014
23,782
133,674
Lorca,Murcia,Spain
Transit PVC
I had a mate who bought a new works van & religiously changed the oil & filter every month. It went in, & came out, looking like Golden Syrup.:LOL:
Oct 1, 2013
7,512
19,937
Lanzarote
Nil by mouth
Lots
Daft question, but you are wiping the dipstick with a cloth before dipping ?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
If you have a tyre pump or small compressor,use it to blow down the dipstick tube to clear residual oil
NOTE I said blow (Draught) down,--- don't create any pressure in the engine
wait 2 to 3 mins wipe stick and dip
G
