Off EHU how long will battery last (1 Viewer)
camocam1
1,112
788
Elgin,Moray,Scotland
bailey approach 760 se
Never been off EHU and only have 1x 110amp batt and no solar panels
So how long will the battery last to run TV and lights and pump etc
Will run fridge off gas as assume
DuxDeluxe
14,660
72,827
Planet Zog
A woosh bang van
Depends very much on the condition of the battery. TV will eat it. If lights are LED then no problem, I would expect a few days or more. Best of luck
43,351
49,573
got to disagree......
modern 15"/19" lcd tv will be around 20 to 25 watts.
110ah battery will power it for around 25 hours continuously
camocam1
camocam1
1,112
788
Sorry should have said TV new low wattage (can't remember what) but only on for 10mins morning and night to get the news
Lights not LED but again only on for about 30mins last thing at night
Pump used quite a bit for showers in morning etc
I assume if I'm driving once van batt fully charged it will then charge leasure battery
Sorry not very technical and still trying to work things out
43,351
49,573
yes and no......
it will charge the leisure battery but very slowly.
once the engine battery is charged, which doesnt take long, the charge current is reduced to a bare minimum and could take several hundred miles to fully charge the leisure battery.
to rely on the alternator charge you would need a battery to battery chargerLink Removedwhich basically fools the alternator into providing full current all the time
lorger
9,666
90,641
Dumfries
Knaus Sun 650MEG
Hi in our old van we didn't have solar panel and like you just had 1 x 110 batt and we lasted 10 days in the outer Hebrides without hook up. We did drive each day and due to long daylight we didn't use much.
s7ev0
May 31, 2010
462
809
Globecar Summit
We've been doing motorhome shows for a couple of years now. Each show is normally three days and nights off hook up, and we never had any problems lasting on one 110ah battery, with our daughter watching TV and using her DVD player. Only ran the battery down once, when it was freezing and we had the fan blower on for longer than the battery could copy with. About 20 mins idling the engine charged the battery enough to last till we went home (don't know if we had a battery to battery charger fitted as standard).
Always meant to get a second battery fitted, which is apparently not too difficult a job, and a cheaper option before adding a solar panel. Cheaper still is to replace halogen bulbs with LED.
As they say, IANAE, but HTH!
Steve :Smile:
Jan 28, 2008
10,122
18,391
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
in the old van we found the flourescents were the worst for knbocking the battery out we had 2 x2 tubes and it could only do a few hours
Mar 3, 2013
1,491
6,190
Poole
We have done 4 nights without EHU ( no tv though ) no problems at all with a similar battery and not driving in between. ::bigsmile:
DuxDeluxe
14,660
72,827
Planet Zog
A woosh bang van
Modern TV - you are right but even at that level of use - it is realistically only a couple of evenings with use of lights etc, etc
I've got an Avtex and in the old van even with low power lighting, the battery (new) didn't last more than three days when the TV was used heavily. New van has solar so no issues
june123
350
134
Staffs
Burstner A class 3 berth
since 2004 caravans before that
EHU
Wouldn't hurt to have a spare battery operated/rechargeable electric lamp with you. Can buy for around £20 or less. Good birthday/Christmas present?
DuxDeluxe
14,660
72,827
Planet Zog
A woosh bang van
Ever the optimists, we have a couple of Coleman LED lanterns. Pretty good and very useful for power cuts at home as well
camocam1
camocam1
1,112
788
Thanks for all the replies just need to convince the boss that she can survive without her hair drier & straighteners
