Normal 230v TV (1 Viewer)
Sep 1, 2022
18
9
Just looking
If you always use site electricity can you just use a regular 230v TV ?
Apr 3, 2018
3,665
10,214
PVC
1995-2004 & 2017》
No reason why not...
Only down side it might not take to kindly to being bounced about in back of moho👍
M
Sep 1, 2022
18
9
Just looking
Thanks for the reply pc. I told my wife I was going to risk being ridiculed but thought it's worth asking what might appear a dumb question. I just don't know enough about the inner workings of the van electrics to know whether or not you just have to have a 12v TV for some technical reason. As regards to being bounced about, there's a dedicated cupboard for the TV with a pull out turntable and straps to tie it down so hopefully not a problem.
Sep 3, 2012
7,557
26,084
Cheshire
C Class Elddis 175
8+ years
Most TV,s also work from 12 volt.,check the back and see if the plug is a transformer plug.it would be useful for it to also work with 12v,when your not on hook up.
Sep 17, 2017
5,476
10,228
Birmingham, UK
A-Class
Might still want to consider a regulator though. The TV might be expecting a nice clean 12v. Then the sun comes out from behind a cloud and your solar gets over excited and starts pumping 14v through the wires.
Jan 30, 2020
2,840
14,501
Mid Bedfordshire
RS Endeavour
Just a tad..
I’ve just updated the TV in our MoHo. 12v TV’s haven’t kept up with modern tech. I wanted a 4K 12v TV but they don’t exist. So I’ve gone for a Samsung 4K monitor and running it exclusively with the inverter.
We are at home at present, so I went out to the Motorhome to watch last weekends F1. I have to say, watching in 4K on a decent size 32” screen was amazing!
Pure viewing luxury whilst away from now on!
May 17, 2022
287
548
Stelling Minnis, Canterbury, UK
Bailey Autograph
Since 1998
Used a "normal 19" for many years, never on a site, and with solar panels could easily watch for 2 or 3 hours a night. It was,of course, run through an inverter. Try not to use water pump at the same time as inverter gets a bit fed up 😕.
Apr 26, 2015
2,775
6,899
Ottershaw
Hymer S820
First motorhome May 2021
I have a Samsung 32" smart monitor it doesn't draw much current so works off an inverter or mains, you can stream tv or connect a satellite system to it but it does not have a tuner built in, but a digi box with hdmi output would probably work if you want to watch terrestrial tv. I got mine from ebay as a refurbished one, but it looked brand new in a Samsung box with all the correct bits with it £150
Oct 18, 2021
2,059
6,232
Mid Devon
Adria Compact SC
Camping since 1954, MoHo 2022
Check the specs of whatever ‘240v’ TV you are intending to use/buy. Many are actually 19v DC and have a 240v to 19v transformer on the 3 pin plug lead.
We have a 22” LG Smart TV/Monitor mounted in the van and power it exclusively from a generic laptop power supply unit fed from a 12v ciggie type socket. Also a Firestick plugged into the USB port on the TV and it all runs perfectly.
Jan 30, 2020
2,840
14,501
Mid Bedfordshire
RS Endeavour
Just a tad..
I keep hearing this, but my research couldn’t find a HD or 4K monitor or TV in a decent size with this configuration whilst looking recently. ☹️
M
Sep 1, 2022
18
9
Just looking
Many thanks for all the responses everyone. Lots to take in. I'll report back on what I do.
Jul 14, 2022
649
1,300
Autosleeper Dorest E
Jul 22
Yeah, never had any issues with ours, nor have our parents either...even with coffee machine and air con on with it
May 7, 2016
7,264
11,755
West Sussex
Carthago Compactline
Since 2003
Possibly because most 12V TVs have smaller screens and 4k/UHD is better on big screens.
May 7, 2016
7,264
11,755
West Sussex
Since 2003
I have also just read that 4k/UHD TVs use up to 30% more power than HD ones. 12V TVs for motorhomes and caravans are probably designed to use as little power as possible.
Lenny HB
53,493
150,285
On the coast in West Sussex
Hymer B678 DL
But surely you will not notice the difference with 4k unless you have at least a 50" screen.
I don't really notice much difference on my OLED screen at home but you are a youngster Harvey so you might. :giggle:
Jan 30, 2020
2,840
14,501
Mid Bedfordshire
RS Endeavour
Just a tad..
Oh it’s marvellous…✔️
32” screen and a noticeable difference between HD and 4K, well to my eyes anyway! 🤪
Jan 30, 2020
2,840
14,501
Mid Bedfordshire
RS Endeavour
Just a tad..
Yes but mine is just in the larger (mid size) screen grouping at 32”. Agree they will use a little more power, but the trade off seemed worth it! 👍🏻
May 19, 2018
246
390
We have a 240v Samsung which has a great thing called magic angle which means you great a good view of the picture even from low angles, great when lying in bed. The 22 inch TV is vesa mounted on a typical office type monitor arm, which absorbs any bumps when driving.
Together with tiny satellite box and firestick, it covers our requirements. It's been transplanted over several vans now, so reliable at 8 or 9 years old.
