No Water (3 Viewers)
CJB
140
60
Kent
1 year
Happy New Year to all.
I have a problem with the water on my MH. Some weeks ago when I turned on the taps I heard the pump running but no water came out. I drove the MH home to take a look and when I arrived the water mysteriously started working again.
However it has now stopped again, with the same problem. I can hear the pump running but no water through the tap.
Any idea would be much appreciated.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Have you either an in-line filter, or a filter mounted on the suction end in the tank?? Maybe even a pump filter??
Or, a leak allowing air to enter the pipework can cause the same effect.
43,337
49,538
if you have run the tank to empty you maybe have an air lock.
otherwise, as above....an air leak somewhere between pump and tank.
17,635
43,369
just guessing you have a diaphragm type pump like the aquasource or fiamma common to many converters. the rubber diaphragm perishes and needs replacing. available as a service kit rather than an expensive new pump
43,337
49,538
damn...never thought of that...but, the op said it happened before and corrected itself.
still worth investigating though :thumb:
Sep 25, 2009
794
1,386
south yorkshire
since 2004. Tugger 10 years on and off
Had the same problem with mine.took diaphram out & cleaned it up. worked for a couple of months then packed up again.bought a new diaphram kit.working like new again.:Smile:
