You need propane when it gets cold...if it's lpg you got from Morrisons that should be fine, check your valve on the bottle is open perhaps?Here at euro tunnel 0 degrees and no gas.
Do you think it's the temperature?
Last filled at morrisons is it butane that won't gas off.
Most likely...you did fill up recently, just wondering if you're low on gas?Sounds like could be a faulty regulator
Purchased in September when I got back from GermanyIf LPG in UK in January it is mostly propane!
Yes done all that.I don't think the Morrisons gas will be the problem as it contains a large proportion of Propane .... check bottle valves are on and any buttons on regulator are pressed.
....... back to faulty reg then.Yes done all that.
Probably worth checking you still have gas ... it may have leaked in that time.Purchased in September when I got back from Germany
How to check? Guide on bottle says green for full.Probably worth checking you still have gas ... it may have leaked in that time.
Are you saying the bottles were turned off causing your problem?Gasit system both bottles were turned off.
Does that mean you have it working now ?Gasit system both bottles were turned off.
Gus, I think they were referring to the cylinders being turned off since last fill up, and use in September, ie, no suspected leakage of LPG.Does that mean you have it working now ?
Haven't you used it since June?The anoint thing is I had this system fitted in June last year to avoid any gas problems.
Glad it is sorted now though or you'd be cold lol
Yes Tryed that alsoAre you saying the bottles were turned off causing your problem?
If they have been turned off and back on there will be a reset button that requires holding in for about 3 seconds.
No have used it in September no problemHaven't you used it since June?
Or did you forget that you'd turned it off when you crossed the channel?
No not sorted went into tunnel crossing so no Internet@laurieash. Is it sorted now? If it is, it would be good to know, and also how you overcame the problem. That may help others who may experience the same problem as yourselves, and would acknowledge those who offered advice.
Cheers,
Jock.
NoDoes that mean you have it working now ?
