No gas to oven (1 Viewer)
BOSTON BSB
BOSTON
COACHBUILT
SINCE 1990
I have a spinflo caprice mk111 cooker and all of a sudden there is no gas to the oven. The hob and grill are fine, the ignition spark is there but no gas. Any ideas?
Dec 12, 2010
5,428
21,692
Cumbria
Not familiar with that model cooker but it sounds like a blocked jet at the oven burner. Just to rule out an igniter fault (dislodged electrode) , try lighting it with a match.
11,958
16,575
If it lights then goes out when you release the knob the flame failure device could be faulty. If, as you say, there's no gas at all I would first check that the isolation valve hasn't been turned off (usually a red top 'tap'). If that is OK then trapped or damaged feed pipe, blocked jet, or failed oven gas control.
B
BOSTON BSB
BOSTON
COACHBUILT
SINCE 1990
Thanks everyone, tried all sorts but no luck, time to have an engineer look at it !
Dec 30, 2008
1,106
2,126
Cheshire
since Dec 2008 after 10 years caravanning
You do have the cooker Lid Open ?.when closed it cuts gas supply to oven.
Eric
Dec 30, 2008
1,106
2,126
Cheshire
Yes i think so Joy, its a safety feature.
Eric
Euphony
481
2,809
Perthshire
B Class
3 years of weekending with the odd month here and there.
I had similar issue when I was completely new to MH’s so didn't know the lid had to be open for oven and grill to work.
Jun 17, 2012
2,938
9,990
North Essex
Autotrail Delaware
>12 but <13
So have you found the problem Joy?
