New water pump advice (1 Viewer)
TheDeckKing
137
114
Hyde, Cheshire
Talbot Voyager 2 coachbui
Newbie
We currently have a very very noisy water pump and are looking to replace it with something quieter. Our moho is 22 years old so I'm struggling to get advice on what would be compatible.
The current pump is a Fiamma superflusso as shown in pic I can't see any model numbers but may if I remove it. Any recommendations for a replacement?
scotjimland
2,331
10,098
A Woosh bang
as John said.. and they are all noisy ..
however, the noise can be greatly reduced if mounted correctly on their rubber feet, ie not to tight, and if you fit an acoustic hood ..
On a more general note, if fitted with solid pipe the noise also travels along the pipes.. fitting short lengths of flexible pipe stops that.. Shurflo sell a kit to do it.
TheDeckKing
TheDeckKing
137
114
Hyde, Cheshire
Newbie
Thanks guys. We've got flexible hoses but no acoustic hood ?!? Will have to research those. Is it a waste replacing the pump then? It seems to work ok, it's just noisy.
scotjimland
2,331
10,098
A Woosh bang
an acoustic hood is basically a wooden box lined with a sound absorbing material like foam rubber.
I doubt you will find an off the peg to suit .. but an easy DIY ..
just make sure you leave space around the pump and with holes for the air to circulated to allow pump cooling.
Try that before spending a wedge on a new pump
TheDeckKing
TheDeckKing
137
114
Hyde, Cheshire
Newbie
I'm guessing I won't be able to swap the existing pump for something like this then
LINK
scotjimland
2,331
10,098
A Woosh bang
LINK
don't see a reason why not.. provided it is a similar pressure and delivery rate to what you have.. check your pump label..
iceni
300
117
Birmingham
Lowline Coachbuilt
27yrs
You can also find pumps noisy if it is fixed to a panel that can itself vibrate, like a piece of plywood for instance. if this can be stabilised then they can be a lot quieter
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
The best noise reduction I achieved was by mounting the pump (using its rubber feet) onto a piece of 1/2" MDF just big enough to accept it. Then glue 1/2" hard foam to the rear of the MDF and glue the whole assembly to its original mounting position in the van. Almost silent. All pumps of that type are noisy and vibrate because of their design. If you want total (well nearly!) silence replace it with a submersible & external pressure switch.
JockandRita
11,462
150,160
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Chris (freelanderuk) has recently been having problems with his really noisy Whale pump. I couldn't believe the noise it was making, when I heard it running. :whatthe:
At the weekend just gone, it packed up completely, and he replaced it with a Sureflo of similar dimensions and pressure. He and I can't get over how quiet it is compared to the Whale pump. He got his from Camper UK.
Cheers,
Jock.
Nov 18, 2011
11,862
43,027
Planet Earth
A van
Over 25 year's
If its not broken don't try to fix it but I fitted a sure flow pump to my wan when I got it only because the pump was knackered
bill
