New tv (1 Viewer)
tick59
1,413
1,409
Newcastle Upon Tyne
"Since 2005"
Bought a new tv yesterday. It has a 3 pin plug to plug to mains which reduces the power to 12v 2a.Can we get a cable that will plug into 12v socket without damaging the tv. phoned manufacturer up said tv was designed to run on cable supplied put they can supply a special cable for £ 60-00p to run on 12v.tv made by CELLO Model no.C16115DVB-LED Ver2. Website=www.celloelectronics.com.
Apr 9, 2013
663
373
Ayr
Newbie
You have three options. A "cheap as chips" 12V lead with appropriate plugs for a few quid, a 12V regulated supply for around £15-£20 from eBay or the unit from manufacturers at £60.
It depends on what level of risk you're happy with. If you want "belt and braces warranty cover", go with the Cello one. If you're happy with a very small risk go with a 12V regulated supply from another manufacturer. If you don't mind taking a small risk then go with the cheapie option.
We went for option 2.
Tim
Apr 13, 2012
5,545
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
Broken Link Removed
Apr 9, 2013
663
373
Ayr
Newbie
Surprised the straight 12v lead is so much. This is what we bought. Broken Link Removed
Can't find another like it now though...
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
I just went to Maplins. I took the existing power lead which came with the TV, so I could match up exactly the small plug on the 12V end of the lead which plugs direct into the TV.
I then connected that small plug to a fused 12V Cigarette type socket which connects to the vans 12V power outlet.
Total cost less than £5.
If you know which size plug goes into your TV you can easily find a pre-made one on eBay.
::bigsmile:
Sep 10, 2013
1,187
18,715
Chelmsford Essex
Getting better
Faced with the same problem after buying a Cello TV went to Amazon and bought a car socket lead for under a fiver works fine, you need to be sure your buying exactly the right power plug as there are a number of sizes. If in doubt visit your local Maplin with the Cello unit and buy a matched up 12 volt lead.
The unit I bought on Amazon was.:
Top LED 5.5Mm X 2.1Mm Dc Plug Led Car Cigarette Lighter Power Cord Charger Cable 1.2M
by
Apr 13, 2012
5,545
18,775
Thanks Everyone ordered one off e-bay thanks for the help.Got the one Burstner recomended only one left and i got it. fun!!!fun!!!fun!!!
I got the other one !! - bought a Cello 20" TV yesterday
(y)(y)(y)(y)(y)(y)..................................:rofl:
Apr 13, 2012
5,545
18,775
Cello C20234F 20-inch Widescreen LED DVD Combi with Freeview
£125 off Amazon(y)(y)
