New journey . 1st problem (1 Viewer)
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
So we've just started our new journey on the Wild Atlantic Way , and I've just stopped to refill up with water , once done I noticed a problem with the lockable filler cap.
No matter what way you turn the key once done when you turn the cap anti clockwise it will open ( as in not spin around freely without unlocking it )
But yet when you turn the cap clockwise it will spin or lock depending on which way the key is turned.
Any idea's , atm I am able to fit the cap ok.. but it just means any passer by could steal the cap / or pollute the water...
Riverbankannie
10,535
61,563
Bristol
IH 630 RL PVC
I would always put my cap on by turning clockwise and then hold in this position and insert and then turn the key clockwise to lock.
Your post implies that it does lock when you do this, in which case there should be no problem?
denisejoe
5,617
12,051
Warden isle of sheppy
Since 2004
Have you upset someone so much that they'd want to pollute your water? You're lucky it's unlocked, our's got mucked up when it was locked. We now leave ours unlocked.
Joe
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
I,m pretty sure that I'm locking it as normal, except when it's locked it's meant to spin when twisted ( turned anti clockwise ) but instead it turns and opens .
Lenny HB
53,448
150,064
On the coast in West Sussex
Hymer B678 DL
Joe
Had that problem with the same type of cap on my diesel filler, when I finally got it off, soaked it in hot water which softened the seals and made it easier to take apart, cleaned it up reassembled it it's been OK for a couple of years now.
fred flintstone
139
75
lincoln
Pilote P690
Since 2007 on and off
I had this problem twice with caps on a brand new E560 a few years ago.
Dealer replaced them. I think they are about ÂŁ15 off fleabay.
R
Robert Clark
Another vote for placing the filler cap in a jug of boiling water - worked every time for me
Aug 18, 2014
23,786
133,731
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
I used vaseline on mine. Before I did it was impossible to remove , just clicked & jumped over the pawls.
You should turn key anti clockwise until it stops to unlock . then with two hands push in cap & rotate anti-clockwise to unlock. When locking you have to make sure the key is still in unlock position & then line up the three locks push in with both hands & rotate clock wise to the lock position, Then when you turn key clockwise to the locked position & remove the cap will rotate in both directions whilst remaining locked.
Hope this helps.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
I just tried "hot" water there and left it to soak in it for 3-4 mins and it never worked.
So should it be boiling water " was frightened of melting/ distorting the cap " and how long should I soak it for.. Failing it working next try how can I dismantle it ?????
As I don't want to waste money on a new one and also have a different key
R
Robert Clark
Cheers how long for ?
Long enough for the heat to travel through the plastic outer casing to the internal mechanism
I'd submerge in boiling water and leave for 5 mins
Our Bessie water cap one had the same issue a number of times and this solution worked every time
Worse case scenario you get a replacement cap, but this way you get to keep the one you have, using the standard key
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Thanks that's is what I would rather do to keep the same key. :)
WSandME
368
453
Wigan-ish
Hymer B660 Bestline
SInce 2006
I first fixed ours by grinding some graphite from the end of a pencil and blowing into the works of the lock - worked OK. I then bought a bottle of proper graphite dust and it's the right stuff for all locks. Lubricates without attracting dust and dirt.
colmorangie
121
53
Bonby, North Lincs
Coach built
Hope you get your filler fixed, however much more interested in what, where, how long the wild Atlantic way is ? Start and finish points pretty please.......(y)
Aug 18, 2014
23,786
133,731
Lorca,Murcia,Spain
Transit PVC
Highlight "wild atlantic way " , right click & then click on "search google for ..." & all will be revealed
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
I will try the boiling water method this morning after I can be arsed to get out of bed & that rain and wind outside goes away :)
Anthea M
Oct 18, 2015
9,501
165,143
Sheffield
Hobby
Since 2009
Had same problem - left cap in boiling water
Fixed
Hope this works for yours?
We put ours in boiling water and it melted! A cheaper version didn't work had to get a Hobby one at huge amount!
Don't use boiling water!!!
jimiol
198
143
Doonbeg Ireland
Coachbulit
beginner, I don't like the newbie term
I can't help with the cap problem other to say you are in Ireland and it's a very honest country I would be amazed if anyone tampered with your water.
I'm not sure if you are doing north to south or south to north either way I hope you have a great time. Have you noticed how bright the stars are yet? If you haven't already done the Clare bit can I recommend the drive between Kilkee and loop head lighthouse please do look up the bridges of Ross and visit, from the Carpark follow the footpath for 5 minutes it an amazing sight.
Wild camping near me can I suggest you think about Carrigholt or on the pier in Doonbeg, near my campsite or on the pier between seafield and quilty.
Please the cliffs of Moher are always busy and the Carpark charges €6 per person! Get you passenger to get out of your MH at the entrance pay the €6 and the passenger can then walk in for free. Doolin is a tiny village but incredibly busy.
Enjoy your travels.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
That part was a joke , as i live in ireland and know how friendly most of the people both sides of the border are :) also we only drink bottled water in the Mh as it's in the fridge and nice n cool :D
Thanks for the heads up on where to make sure and see :)
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
We bought a new cap for our E560 years ago, got fed up arsing about with the original cap.
Jaws
23,836
72,493
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Lenny HB
53,448
150,064
Hymer B678 DL
Tip for you.. When you do the Ring of kerry, go anti-clockwise .. We was told this by a coach driver..
In all honesty I still have no idea why.. other than there was a hardly any traffic on our side of the road while tother side was often chocka !
I got it wrong bl**dy nightmare.:D
jimiol
198
143
Doonbeg Ireland
Coachbulit
It's so you are going in the same direction as the coaches therefore not coming to them face to face.
