Need more power (1 Viewer)
errpaul
538
83
Wiltshire
11 yrs
So getting to grips with being self sufficient when away in the motorhome.
I have fitted a 150w solar panel and we have 2x 110ah batteries. In this October overcast weather that provides us enough power to keep going with a little use of the heating.
We however plan to use the van throughout the winter, being static for up to a week. Obviously that means far less power from solar, and far more use of the heating (blown air ).
As I see it the options are:
- Larger battery bank (not ideal as current batteries are only aroumd a year old)
- Additional solar panel
- Battery to battery charger (could run engine as and when needed to charge batteries I think)
- Generator
Any advice or experience of systems would be appreciated
funflair
19,352
30,242
Guisborough
MORELO palace
since 2012
I would certainly say more solar, at least the same again and then see how you get on, I don't see the point of bigger battery bank if you can't recharge it.
As you have found the gain from solar is pretty low when the weather is grey.
Martin
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Though I'm a fan of solar, theres no doubt its not a lot of help in a grey winter. I would recommend the B2B charger, it is always available.
Generator much more expensive, heavy, noisy and a fairly low charging rate if you are just using the MH built-in charger.
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
As said above, no point in having a bigger battery unless you have the means to charge it.
We have fitted twin 225AH AGM battery sets, two sets of two 100W panels and twin controllers, but that still leaves you exposed on a cold wet week in the north of the UK with virtually no usable light.
For these situations we have two 50A power supplies that are rigged to work as chargers and shore supplies, leaving you the option of pulling into a CL for a night to get the batteries charged up to 85-90% of capacity overnight, given that EHU is available.
It is pretty much forgotten that a mains charger can be used as a shore supply as well, and if you have the facility to charge up your batteries quickly, you won't get the walk-down on capacity that happens when they are not fully charged each day and start the new day with less capacity than the previous day.
If you look on ebay for 13.80V Power supplies:
13.80V 30A Switchmode power supply £19.99 Free postage
13,80V 50A Switchmode power supply £53.00 Free postage
These are all adjustable within 5% or so, even the ones sold as 12V output for LED lighting are adjustable up to 14V in most cases.
We have two 26A in the trailer and two 50A going in the Mercedes. There is also a 24V 10A unit for the vehicle batteries plus a Durite B2B unit as well.
Peter
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
I would get as many solar panels as you can, you could add another battery or two, batteries a year old will have almost the same capacity as a new one, so, as long as your new batteries are the same size ( and make, if possible) they will work well together. I did that, no problems. Peters tips above are very good, but, when all else fails, use a generator. As long as you are far enough away from annoying other people, they can be a lifesaver, and they don't have to be smelly heavy or noisy if you buy a good make. We store ours in the van when not in use, and you would never know it was there.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
In winter, nothing beats 230V mains to the charger so I would suggest using sites where you can get a hook-up or carry a small inverter PSW generator such as the Honda EU10i (quietest) or perhaps one of similar spec (but probably a bit noisier).
Jaws
23,836
72,487
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
At the very least 300w of solar panels.. But more would be better ( of course :) ! )
Blown air heating systems are REAL power hungry.
The other option is to look at a diesel powered heater,
They are cheap to run but having said that, most will draw about 2 to 3 amps anyway.
A third option is to do what we did in the Miller. I bought a flu-less catalytic heater.
It was not perfect as it was only a small one, but used virtually bugger all gas, NO electric, and kept the chill out of the van at night so we were not freezing when we got up in the morning :)
eddie
8,157
41,270
Taunton Somerset
RV
since 1989
- Generator
Or frankly all of them
Jul 13, 2008
3,739
3,872
Low profile
Peter
Have you got any eBay links to the said power supplies? Thanks.
Paddywack
1,211
2,281
Neasham, Co Durham
Hymer ExsisT588
We have two leisure batteries and a solar panel Truma blown air heating (6E), up north off grid we can last 3 - 4 days. We purchased Broken Link Removed I look upon it as another battery - it provides that fall back position and being totally isolated form everything else if I do draw a bit from the engine battery at least I know I can always get started.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
A2B or B2B is the best suppliment in my opinion.
We go skiing and stay stationary for up to a week at temperatures as low as -20. Inside the van, the diesel fired Webasto dualtop heater maintains T-shirt weather!
The A2B charger keeps the 345 Ah traction battery bank topped up with an hours run of the engine each day. Charging current is about 90 amps under these circumstances.
We don't have solar or a generator.
The final 2 days we just run the battery down and recharge for free on the descent back down the mountain.
Feb 27, 2011
14,737
75,993
UK
Self Build
As Eddie says if you are using your van all winter then having a choice of power sources is advantageous.
A B2B will put 50 Amps in. Sterling do a 60Amp battery charger.
If you go with a generator get the biggest charger you can afford that is suitable for the battery bank size you have. This means you run the generator for less time. If you are driving about then the B2B can keep you topped up. More battery bank means you last longer before needing to charge. More solar even in winter can help a little. I can get up to 20AH back into my batteries in winter on a bright day (last time I tested).
I have a rule of thumb that says have as much solar (Watts) as you do in batteries (AH). I currently have 180W of solar and 220Ah of battery.
I would like to have more and when I build the new van will have more roof space and payload so will try and get up to 500W and 500Ah.
On my second van I had 1000AH of batteries and 240Watts of solar. I could go for 10 months of the year without hookup. In Dec and Jan I had to hookup once every 2 weeks.
TerryL
6,187
8,189
North East
Low Profile
B2B - it charges your vehicle battery first - which doesn't take long - then any spare alternator capacity is used to charge the leisure batteries. The Sterling we've got fitted also has an intelligent charging system that protects and revitalises the batteries.
Warning though - either system will put a load onto the alternator higher/longer than they were designed for so make sure whatever you get has an alternator overheat sensor/cutout - I know the Sterling offering does.
I'd go for the B2B first, rather than additional solar panels or batteries simply to avoid the additional weight.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
A2B wipes the floor with the B2B product.
It is a more difficult installation however. Many auto electicians will run scared.
I have installed the A2B product due it's better performance.
Most will go for the B2B product for simplicity and the avoidance of base vehicle warranty issues.
errpaul
errpaul
538
83
Wiltshire
11 yrs
Peter
Thank you. Although it is probably actually very simple that sounds a bit too complicated for me and my level of knowledge at the moment ☺
errpaul
errpaul
538
83
Wiltshire
11 yrs
Do you have a model or anything for the flu less heater you used?
I think I may be able to get another panel up on the roof but would have to measure carefully and would not leave any space to walk to get to the front of the roof if needed. It seems that the general consensus is a2b or b2b as a next step.
Jaws
23,836
72,487
Thetford Norfolk
C class, Chieftain
Sorry.. no model or even make..
I just went to the local Volvo truck dealers and bought a cab heater..
Not 100% sure but I MAY have it still, as I removed it from the miller when we changed vans.
The new ( to us ) van has a proper heater in it ( old school Carver type ) so it was not needed.
Lenny HB
53,435
150,021
On the coast in West Sussex
Hymer B678 DL
No they aren't, a Trauma Combi takes about 5 amps with fan on full until the van is up to temperature for 15-45 min depending how cold it is then the fan speed drops and it takes less than one amp, less than your LED lights consume.
Jaws
23,836
72,487
Thetford Norfolk
C class, Chieftain
So you do not consider a 5 amp draw high ??
And my LED's draw .1 amps each.. the strip lights draw around .45 amps
If you LED's are drawing an amp ( about the same as a standard 10w incandescent in fact ) I would get them looked at !!
Lenny HB
53,435
150,021
Hymer B678 DL
It is only for 15 minutes or a longer if it is cold, as I said it is less than one amp once up to temp, 0.75 a to be precise when I measured mine.
Like most I don't run with only one light on in the van so the Truma does draw less than the lighting.:)
Jaws
23,836
72,487
Thetford Norfolk
C class, Chieftain
I guess because of the size of out vehicle we cannot really compare.. Our blower is always on for a lot longer than 15 minutes !!
We usually have 2 x led strip lights on giving a draw of around .9 amps
