Need a longer leg (1 Viewer)
Mags52
1,433
1,731
Melrose Scottish Borders
Hymer B774
Since 2010
Our Autotrail Miami (2007) has a Fiamma table with the single leg that drops into the base in the floor. It is just a bit too low - we struggle to slide under the table to sit down because of the depth of the seats. Any ideas how we can lift the table height?
My first idea was to take the socket off the base of the table and put a piece of wood under it but then realised that the cupboard designed to hold the table is exactly the right depth so it wouldn't take the adapted table.
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
How about an old gazebo leg where you can adjust the height with the pop out stud things.
Mags52
Mags52
1,433
1,731
Hymer B774
Since 2010
Good idea Sandra but unfortunately the Fiamma legs have to be exactly the right diameter for the base.
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Go buy a blank piece from B&Q then. They have them all lengths and sizes then drill a hole for a pin or something to secure the two pieces together :)
Do you have a photo?
Mags52
Mags52
1,433
1,731
Hymer B774
Since 2010
Broken Link Removed a picture. The leg is hollow aluminium with tapered ends to make it stable in the sockets. I think it would be difficult to replace or adjust. Fiamma has brought out a newer model with plastic ends that can be reduced in length but not increased. They do make a tripod that may lift it off the ground so will enquire about that.
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
What length is yours, I have one in the shed, I will check it tomorrow and see if it's longer.
Cheers, Dave(y)
Feb 16, 2013
19,735
52,032
uttoxeter
ambulance conversion
50 years
If you can get another leg you could cut the two of them and join the two longer pieces together, don't know how without having a go at it but maybe a couple of slots in one with a hacksaw or welding or another smaller diameter tube slid in.
Mar 16, 2010
3,057
30,742
Carmarthenshire
In between
Since 1988
They do come in and different sizes Margaret I seem to remember we got a longer one for our Miami...we also had the tripod so we could use it outside
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
:D:DOld Mo needs a longer leg, he cannot get it over anymore:D:D:D
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
What diameter tube is it? just get some same size tube & get it welded in to lengthen it, or a second leg to cut a piece out of.
Mags52
Mags52
1,433
1,731
Hymer B774
Since 2010
Did you find that the tripod made the table taller Anne? Looking at it it seems that it would but not sure.
TheBig1
17,630
43,280
i have had that type of table before and find they tip too easy on a tripod. plenty of legs on ebay all different lengths
TheBig1
17,630
43,280
Mags52
Mags52
1,433
1,731
Hymer B774
Since 2010
Cheers, Dave(y)
Sorry Dave, I thought I replied to this last night. It's 68cm.
Just looked and I had replied ... Duh ... sorry for the repeat.
Thanks very much Mags
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
The one I have is 68cm too, as people have said, plenty on ebay
Cheers, Dave(y)
Gellyneck
9,235
18,210
Scotland
More than toes wet now!
Mags, assuming the existing table leg is hollow if you know anybody that's got a wood-turning lathe they could turn a piece of timber to any length (height) you want. Try Goggling cabinetmakers in Bathgate?
Part of the length would be turned to the internal diameter of the existing leg with the "additional height" the same diameter as the outside diameter of the leg.
Might be worth a try.
Gellyneck
9,235
18,210
Scotland
You'll, obviously, have thought of the alternative option. Take the cushion off the seat!:eek::giggle::p:whistle:
D
Deleted member 29692
Looking at Fiamma's site it appears that they supply it as standard at 70cm which you can then cut down to suit so it appears that you already have it at more or less full length.
http://www.agentfiamma.co.uk/Fiamma-Table-Leg-System.html
As has been suggested you probably need to get hold of another one to cut down and figure out a way of joining them or maybe get something made up out of wood or aluminium tube.
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
This may sound daft but what about cutting it in half then buying a piece of tubing to slot inside it . Then adjust the height to what you need drill through both and either bolt or rivet together again? I think I would drill various holes in the new piece of tubing and put a steel pin through. This would give the option of varying the height to suit.
Mags52
Mags52
1,433
1,731
Hymer B774
Since 2010
That sounds like a good plan. I'd need to get someone to do it for me as I don't have the right tools and would want to make sure there were no sharp edges. Thanks
