My tip with ramps and levelling (1 Viewer)
bernardfeay
613
1,191
Bolton
hymer exsis
10 years
I often spot motorhomes attempting to get level by using two plastic ramps which have a total height of about four inches each. Fear of overshooting means that they raise the MH by about two inches on each wheel and the benefit is marginal at best.
I use just one plastic ramp but I have screwed a three inch plank to the underside. It is bevelled on the edge so that I get a smooth run up and with help from my wife I can usually get at least six inches of height gain. (Prior to editing this read "I can get a good six inches up.")
I can always spot which is my lowest wheel and simply getting that one higher makes all the difference.
Feb 5, 2014
1,700
3,988
mid-Norfolk
since 2006
My Dad made wooden blocks, tapered at one narrow end with a 1" square cross piece raised above the other end, each with 2 holes drilled in them. Apart from the bottom (longest) plank, each block had 2 dowels which located in the holes of the next shortest plank, whilst butting up against the cross piece. He could raise the van in 3" steps by upto 18inches, using 6 planks: the longest was 24" and the shortest 6". Slightly heavy, but very flexible.
The most interesting attempt at levelling that I saw was a German in a VW camper in Scotland, at the CCC Ardgarten Site (now closed). Loads of wooden beams were freely available as it was a forest site with reasonable slopes. He constructed a platform where a level spot turned into a steep drop and reversed onto the platform. It took a dozen attempts before he was happy, by which time the platform was 5 feet above ground level! The only things stopping him overshooting were his brakes and a warning from his female companion.
It is quite unusual for us to use our ramps; everything seems to work so long as we are reasonably level and we rarely stay still for more than a couple of days - Gordon
bernardfeay
bernardfeay
613
1,191
Bolton
hymer exsis
10 years
I'm not sure if people realise that raising just one wheel actually lightens the load on the springs of two other wheels, thus making them a little higher than they would otherwise be.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I use two 4" (if you're lucky!) Fiamma ramps and rarely fail to level. I'm always surprised at how much levelling can be achieved by a little wiggling around within the pitch. Or by choosing another one. :)
Dec 28, 2011
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
Pair of Milenco Quattro's does it for me.
16cms (just over 6") maximum and curve stepped.
Never overshot them, yet, and most times I don't need to have the hand brake on. Always left in first gear though. You can feel each step as you go up onto the ramps.
Offset them by one step or more for side to side levelling as well.
Never had a problem with them and almost always end up level.
If the pitch is such that even the Milenco's can't cope, move.
sean n maggie
672
327
leeds
autotrail
i can usually look at a pitch and decide drive in or reverse in,,as our autotrail lot higher at back , then look how pitch slopes etc to get almost level before using ramps to get it right,,,,cant have the brandy spilling over the glass through not being level.....the pint glass takes a lot of filling,,so NO spilling....:whistle::whistle:
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
What a great idea!! (y)(y)
Feb 5, 2014
1,700
3,988
mid-Norfolk
since 2006
It took me a while to realise that if I park ACROSS the slope, the difference in heights is much less! :oops: - Gordon
