Can you get joining tape in the same colour as the board? I had an Autosleeper repair done that way (not damp, it just unglued itself a bit)
I’ll have a search for it.
as i said in my earlier post try to get some offcuts of mahogany from a local window company, this is hardwood and will last the life of your m/home. you will probably have to shape it to size.Interesting, what type of wood should I be using? and how / where do I get it pressure treated?
It’s looking like a couple of short lengths are required? is pressure treating them necessary?
Be aware if looking again that O'Leary only have a fraction of their stock on the website. Having been there, it's just up the road, can understand why.I did look 0n the O’Leary website but couldn’t see the right wallboard. Magnum’s definitely have it though. Going to buy a 4 pack of it. Kenkle I believe it’s called.
If you cut pressure treated timber it is less resistant at that point. If cut to size first the treatment is equal all around, as the treatment does not penetrate right through the timber only X amount in to the timber.Better still, buy pressure treated wood. All the sheds stock it, if you can find an appropriate size. Freshly treated wood shrinks as it dries.
Buy multi-tool blades on eBay, they're really good and much cheaper.
Stixall adhesive won't disolve anything, is very strong, and cures in the presence of water. It'lI stick more or less anything very well, but doesn't cure quickly in the current temperatures (unless you use your heater).
It's rated for outdoor use, so should be fine as (covered) framing. And if the cut edges are a concern, just treat them.If you cut pressure treated timber it is less resistant at that point. If cut to size first the treatment is equal all around, as the treatment does not penetrate right through the timber only X amount in to the timber.
There are also non setting sealants, for example . These don't set, and seal supported joints which might flex. For example an awning rail (or your windows and Thetford type doors) might be sealed with it, but they won't hold any unsupported weight without a mechanical fixing.Thanks for all the tips fellas.
Another thing I need to ask about.....when I took the doors off, there was old sealant everywhere. It looks like no nails as it was a buff / grey colour and was still soft? Was this a previous attempt at sealing using ‘no nails’? or is this decent stuff a d that is how decent stuff ends up?
There are also non setting sealants, for example . These don't set, and seal supported joints which might flex. For example an awning rail.
Be aware that in some situations it is better to use non setting sealant rather than the PU adhesive /sealant such as Sikaflex.
Fitting of roof lights is one situation but there are others where it is preferable.
Great thread by the way
If your planning to stop the leak, as i assume you are, then there is no need to use pressure treated materials...
I only know what I was told by the treatment place. I only delivered the stuff to manufacture. Also they don’t use off the shelf sizes some of it is run up to their spec. But I would stand corrected by people with greater knowledge.It's rated for outdoor use, so should be fine as (covered) framing. And if the cut edges are a concern, just treat them.
So, it more than likely was something like no nails then? It feels like putty.
I’ve seen it in other places on the MH so, I’d love to know if it’s crap stuff or if that is how it is supposed to look?
I don't need any but yours is the same wallpaper as mine. Always handy to know where you got it incase me or anyone else needs some in the future. You are doing a great job , thanks for posting. It's an interesting thread.They dont’t have the wallboard paper but, I found that on another site.
similar to this, installed at factory https://www.ebay.co.uk/i/161414003222?chn=ps
So this stuff will be ok to run around the door frames to help bond those. Then, run a sealant round the outside of them?
Looks like you are doing a great job, I've been there & done it on a caravan many years ago.
When you glue the wall boards back on you obviously need to brace them to keep the board in contact with the adhesive, also what you must do is brace the outside wall of the van as well or you will probably end up with a nice curve in the wall (guess how I found this out).
I'm not a fan of the mastic bedding strip, it tends to shrink in sunlight, I would stay with Sika products.
