Mppt Controllers (1 Viewer)
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
Last year when I fitted my solar panel, I used one of these 20A controllers..
Broken Link Removed
I have been reading that the MPPT ones are more efficient and wondering if it's worth changing.
We'll be mainly in Lanzarote where there's plenty of sun :)
If it's worth changing, is it just a case of swapping over ?
And any recommendations of a reasonably priced one please ?
Many thanks :)
Jim
Ringleader
Jul 19, 2007
36,421
130,932
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I believe that some can be much more efficient as others, twice in some cases. So It's worth buying a good one. I know @eddievanbitz did tests with some, but I forget the actual result, except I learned that Chinese and cheap isn't the bargain I thought it was.
Yorick
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
I believe that some can be much more efficient as others, twice as in some cases. So It's worth buying a good one. I know @eddievanbitz did tests with some, but I forget the actual result, except I learned that Chinese and cheap isn't the bargain I thought it was.
Thanks. I'll PM him :)
eddie
8,157
41,271
Taunton Somerset
RV
since 1989
On my on motorhome I have three identical 130 watt solar panels. This gives me the ability to compare regulators in a like for like situation.
Three "alledged" MPPT regulators gave us a range of 1.9amp - 4.9amp
The Victron MPPT being the unit that always outperforms others. It retails at about £110 and is available at many outlets.
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
Yorick,
a good MPPT here - been absolutely outstanding all the time its been fitted. External 'dashboard' too so the main controller can be hidden away. She's blinking (fully charged) 90% of the time.
Got mine from Sunsolar.
Hope it helps,
Regards,
Trikeman.
Yorick
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
This looks the daddy :)
http://www.ebay.co.uk/itm/Victron-E...t=LH_DefaultDomain_3&var=&hash=item46326a3009
Do you really think the extra cost is worth it ?
andy63
4,672
15,017
south shields
None
since 1990
There seeme no doubt that the mppt is the one to go for ,but then which one.. Having said that my portable came with a pwm controller and without any specific tests seeed to do the same job as my now fixed panel with a mppt controller..
I suppose the question is does your current set up do what you want or not and does any likely gain justify the cost...
Best of luck with your decision...
Andy
Broken Link Removed
andy63
4,672
15,017
south shields
None
since 1990
Yorick,
Hope it helps,
Regards,
Trikeman.
Same one I fitted only without the remote panel as I already had a power management panel. As said seems to do the job but no direct comparison such as Eddie has carried out.
Andy
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
If you don't have many watts and you are in Lanzarote it's not worth paying the high price for an mppt as it will make little difference in that climate
Better to increase your watts surface area for the same or less money
Yorick
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
That link looks dodgy. There are different controllers in the pictures. The SSP is £110
The pics show all their range. Can select from the drop down list :)
I assume I need the 75/15 for a 150w panel ?
BlueSolar MPPT 75/10 (12/24V-10A):
MAX PV power is 135 Watts at 12VDC, 270 Watts at 24VDC
BlueSolar MPPT 75/15 (12/24V-15A):
MAX PV power is 200 Watts at 12VDC, 400 Watts at 24VDC
BlueSolar MPPT 100/15 (12/24V-15A):
BlueSolar MPPT 100/30 (12/24V-30A):
MAX PV power is 440 Watts at 12VDC, 880 Watts at 24VDC
BlueSolar MPPT 75/50 (12/24V-50A):
MAX PV power is 700 Watts at 12VDC, 1400 Watts at 24VDC
BlueSolar MPPT 100/50 (12/24V-50A):
Yorick
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
So are you saying that in very sunny places, the controller is less important ?
And I am thinking of also getting a 100w portable panel as no more space on the rof.
Techno
Jul 28, 2010
15,475
20,756
May 2010
There are separate prices for each you have to select one for the associated price
The 75/15 is widely available at £85 or less but looks very basic.
I'd very much like to see one with the lid off
eddie
8,157
41,271
Taunton Somerset
RV
since 1989
I recommend reading the white paper on Victron website
The main benefit of a "good" MPPT controller is that it can make hay whilst the sun shines, literally. So Its really sunny in the morning, and cloudy in the afternoon, the higher, controlled charge from the MPPT regulator during the morning will be beneficial. If you have a mainly sunny enviroment, and you have a smallish battery bank to store the charge having a more effecient charging regime is pointless.
The key word here is "mainly sunny" lol as opposed to "rarely sunny
Yorick
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
thanks. I'll have 2 x 110a batteries to keep a fridge cold. So if I can get a bit mire power for not big bucks, then good.
Yorick
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
P.S. I'd have thought that when sunny all controllers be the same.
And in poor conditions, the better ones (MPPT) drag more power out.
Or am I still not getting it ?
Techno
Jul 28, 2010
15,475
20,756
May 2010
That's pretty right but read the White paper
I'm on shitty ship wifi just now so difficult to give you links
Techno
Jul 28, 2010
15,475
20,756
May 2010
My controller on a good day producing over 6 amps more than the combined panels rated output (that is in MPPT mode) you can recognise this by the charge voltage which will only be a little over half a volt higher than the battery voltage. Bringing the voltage down allows higher current for the same wattage. A PWM regulator cannot do that
This will cost about £110 by the time parcel farce hit you from Taiwan
DBK
18,029
48,099
Plympton, Devon
PVC, Murvi Morocco
Smashing. That's saved me some dosh :)
But note the last few words from the Conclusion here, which I have highlighted:
"The MPPT controller will also harvest substantially more power when the solar cell temperature is low (below 45°C), or very high (above 75°C)"
I guess the question is under the sun of Lanzerote how hot is the black coloured solar panel going to get?
But I am sure you could fit it after you get there if you find on a hot day the fridge is struggling to keep the beer cool. :)
Yorick
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
Bugger. So they both work about the same when very sunny, but not when very hot ???
Confused ? me ? no ;)
IanS
14
14
Glasgow, Glasgow (City of)
Overcab
A long time
My understanding is if your panel is putting out say 3 amps at 20 volts, an "ordinary" controller will output 3 amps at 12 volts, just dropping the voltage from 20 to 12, but an MPPT controller will convert the 60 watts (20 x 3) to 60 watts at 12 volts, which is 5 amps (minus a bit for inefficiency in both cases)
It was years ago I read up on this, so not 100% sure
g8ysn
638
417
ng219ep
coachbuilt
Yorick,
Hope it helps,
Regards,
Trikeman.
Same as mine
